custom exhaust
custom exhaust
is it possible to make an exhaust system that comes out of the side right befor the rear wheels on a 2001 trans am....if anyone has has done this can i see pics or how much do u think it would cost to do???
since thered be no way you could do it without incorporating it into the side ground effects (unless you wanna replace your exhaust tips once a week) itd probably cost a good bit more than a regular catback, at least for a good job. figure 200-300? or so for piping and a pair of mufflers and then more for tips depending on how nice or fancy you wanted, then the paint work and mods to fit the tips around or into the side molding. i forget what car it is, might be the new silverado ss but it had some nice trapezoidish looking tips incorporated into the side before the rear tires, with the shape of the side molding before the rear tires on t/a's, tips that shape would look sweet.
yes it would be possible, i have seen it done. dual outlets side by side with rectangular tips exiting through a custom cut hole in the passenger side sideskirt in front of the rear tire. it was all custom work, done by both the car owner and a local speed shop.
Do a search, there is a member that has it done and it looks OK. He also has a bad *** car and a bad *** motor to back it up! Someone was talking **** about his car but then he posted his mods and they got real quiet. The car is black and the tips were chrome. He did not put them in the side molding either.
