LS7 lifter #
LS1Tech Premium Sponsor
Single = 17122490
Singles are pretty expensive though....if you're needing more than 3 or 4, it's less expensive to buy a full set!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
You only need one because you have one that went bad in your setup? If so, what lifters are in it now? The reason I'm asking is because I believe they are a bit taller than stock lifters. If you are changing one out, you may want to go ahead and change all of them. Just my .02 cents
I currently have LS7 lifters with less than 300 miles on them, I have reason to believe 1 of them has failed. I have 1 that isnt pumping oil through it anyway. So Im going to replace only the 1.
