using available licenses with efilive
Old 01-13-2011, 12:41 PM
98trans-am's Avatar
Default using available licenses with efilive
Hey everybody.I bought efilive flashscan v1 from a memeber a while back and have just started using it. well there is one available license left on it but it wont let me use it because it says i need an activation key. i can see on the licensing screen that slot two is available and one has been taken up from the previous owner. should i contact efi live for a key or should it just be readily available?
Old 01-13-2011, 01:04 PM
MawneeC5's Avatar
Did it include a disc? I found my key in a text file on the disc.
Also being a 98, do you even need one? Pretty sure EFIlive can tune unlimited 97/98s without burning a license
Old 01-13-2011, 01:22 PM
98trans-am's Avatar
it did include a disc but for software installation and it wasnt the original disc either.not sure if 97/98s are unlimited. ill try contacting customer support.
Old 01-13-2011, 01:24 PM
rpmauto's Avatar
97 and 98's are unlimited.
Old 01-13-2011, 02:18 PM
MawneeC5's Avatar
Double check that disc! Mine doesnt look original either and it had the keys on it in a text file.
Old 01-13-2011, 02:27 PM
minytrker's Avatar
Yes 97 & 98 don't use a license at all.
Old 01-13-2011, 05:34 PM
98trans-am's Avatar
thanks for all the replys. if its unlimited than i should be fine. i have a more noligable buddy coming over later tonight maybe he can show what im doing wrong.
Old 01-13-2011, 10:27 PM
joecar's Avatar
Post a screenshot of the license page.
Also, you need the registration key from the "blue" card... if you don't have the blue card, goto the EFILive forum and pm/email me the serial number of your V1.
The 98 stream should be enabled, but if it isn't, it can be activated with a code (the 98 stream is included free).
Old 01-14-2011, 07:49 PM
98trans-am's Avatar
I had my tuner come over last night check out the car for me. we ended up using my efilive and it was able to tune it witout needing the available license. thanks for the responses.
Old 01-16-2011, 01:29 AM
Quick99Si's Avatar
Is it possible that you have a 99+ PCM?
Old 01-16-2011, 01:56 AM
macca_779's Avatar
Wouldn't matter as he has a spare licence. What it looks like he hasn't done is register the software with the key.
Quick Reply: using available licenses with efilive
