Special Edition Vehicles - 1997 camaro ss lt4-how to determine
CHIPD
01-14-2011, 11:34 AM
Looking at 1996 and 1997 Camaro SS's. Used to own a '96 SS Hardtop 6spd.
Anyway, i have found a 1997 Camaro SS that is white with the orange stripes, 6 spd and hardtop. How do i find out if it is 1 of the 100 LT4 cars that were produced??? do i have to call SLP or can it be determined in the VIN or RPO codes?
Z28/2002
01-16-2011, 05:13 PM
Should be able to tell by the RPO's but SLP can tell you with the VIN.
Waiting on Xsta Z 28 to post in here, he has car #6. There is a thread on it here
http://www.ls1tech.com/forums/special-edition-vehicles/787620-brought-home-lt4-ss-6-a.html
Xlerator
01-16-2011, 08:42 PM
I have LT4 #18. If you have access to the car, you should be able to verify if it was an LT4 car by the SLP options door sticker (RH Door), it should actually state LT4 SLP Car #:_ _ _ . If you look under the hood, the Emission sticker on the radiator shroud should state that the engine is an LT4. I would think those two stickers may have been overlooked or missing if it was a fake LT4.
JohnnyBs98WS6Rag
01-28-2011, 11:11 AM
I'm pretty sure that since SLP did the LT4 swap, the GM factory RPO decal won't have LT4 on it. CompNine's database doesn't contain any f-bods w/ RPO LT4.
I'd be interested on seeing a RPO decal on a legit LT4 car. I suspect it has LT1.
Z28/2002
01-28-2011, 01:59 PM
Looking at the pictures of Xsta Z's car, the RPO sitcker shows LT1. Even the SLP sticker doesn't show the LT4 on it but the emission sticker on the radiator supports shows LT4
http://i16.photobucket.com/albums/b28/shudbdrwg/1997%20LT4%20Camaro%20SS/IMG_2464.jpg
Xsta Z 28
01-31-2011, 10:55 AM
Other than "appearance" there are no "codes" on the car to say it is a LT4 . . the intake should be red, the tail panel should have an orange 330 hp decal and the above shown decal changed by SLP.
http://i16.photobucket.com/albums/b28/shudbdrwg/1997%20LT4%20Camaro%20SS/IMG_2450.jpg
One needs to do a lot of homework to prove a LT4 in there.
Here is a break down of the RPO's for 1997
AG1 Power Driver's Seat
AK5 Inflatable Driver and Passenger Air Bag
AR9 Deluxe Front Bucket
AU0 Remote Keyless Entry
AU3 Electric Door Locks
A31 Power Windows
A90 Power Deck Lid Release
B35 Carpeted Floor Mats
B84 Exterior Moldings
CAE Handling Charge From St. Therese to SLP
C49 Rear Window Defogger
C60 Air Conditioner w/ Manual Controls
DG7 Body Colored Electric Remote Controlled Mirrors
DL5 Roadside Assistance Decal
FE2 Ride Handling Suspension
FE9 Federal Emissions
GU6 3:42 Rear Axle Gear Ratio
G80 Limited Slip Rear Axle
IPC PC Interior Trim Design
J65 Power Front and Rear Disc Brakes
KG9 140 Amp Alternator
K34 Electronic Cruise Control
LT1 MFI HO 5.7 Liter V8 Engine
MM6 Tremec Manual 6 Speed Trans 85 mm, 2.66 1st and 0.50 O/D
MN6 Manual 6 Speed Provisions
NF2 Tier 1 Federal Emissions
NP5 Leather Wrapped Steering Wheel
PE0 Wheel Related??
QLC Tire P245/50R16 N BL R/PE ST TL HW4
R7A Sales Item #26
STE Plant Code St. Therese
T82 Automatic On/Off Head Lamps
T96 Front Fog Lamps
UA6 Theft Deterrent System
UB3 Instrument Cluster, Oil, Volts, Tach
UL0 AM/FM Cassette
UZ7 8 Speaker, Quad Front Dr. Mounted, Sail Panel, Dual RR Hatch & Amplifier
U1S Multiple Compact Disc Player
U73 Fixed Mast Antenna
V73 USA/Canada Vehicle Statement
WU9 30th Anniversary Camaro SS Appearance and Performance Sales Package
Z28 Special Performance Sales Package
Z4C 30th Anniversary Package
1AY Stock Order Modification
1SJ Option 9 Package
1SZ Option Package Discount
10C Arctic White Cloth Trim Combination
10I Arctic White Interior Trim
10Q Arctic White Molding Color
10U Arctic White Exterior Color
6HD Computer Select Suspension Component Front LH
7HD Computer Select Suspension Component Front RH
8TH Computer Select Suspension Component Rear LH
9TH Computer Select Suspension Component Rear RH
Other codes of note to see would be:
R7T
WU9
I have also confirmed with another owner that the harmonic balancer appears to have been drilled with a "weight" hand printed on the balancer like so:
http://i16.photobucket.com/albums/b28/shudbdrwg/1997%20LT4%20Camaro%20SS/IMG_0270.jpg
Car should also have the Quaker State SynQuest Synthetic Lubricants Package, and the Twin Dual Tip Exhaust.
http://i16.photobucket.com/albums/b28/shudbdrwg/1997%20LT4%20Camaro%20SS/IMG_2463.jpg
Exhaust resonator:
http://i16.photobucket.com/albums/b28/shudbdrwg/1997%20LT4%20Camaro%20SS/IMG_2449.jpg
Xsta Z 28
01-31-2011, 11:02 AM
And here is the other decal Xlerator speaks of:
http://i16.photobucket.com/albums/b28/shudbdrwg/1997%20LT4%20Camaro%20SS/IMG_2443.jpg
The top line states: "LT4 SLP Car #:000"
Brangeta
01-31-2011, 01:01 PM
Concerning Xsta's post; R7T is the RPO code for a '96 and '97 SS. A '96 or '97 SS must have that code or it isn't a real SS.
CHIPD
01-31-2011, 10:36 PM
thnx for the info all. especially xstaz28. your car is amazing.
Xsta Z 28
02-01-2011, 08:56 AM
Unfortunately that is not a 100% MUST . . My car does not have a R7T code, and I discussed with Dave H. that WU9 . "forced" the R7T . . which the purchasing dealer must have forgotten to check. . . .
So fun when there are "nuances" that make hard and fast rules not true . .
Xsta Z 28
Thanks, and you are welcome for the info.
Brangeta
02-01-2011, 10:47 AM
That's weird. I haven't heard that one before. :confused:
Xsta Z 28
02-07-2011, 09:36 PM
Ain't it fun trying to "discern" all the data? . . . I read the R7T thing and then looked at my car to find it did not have it . . . I was Like WTF? . . . But after chatting with Dave I was put at ease.
Brangeta
02-08-2011, 09:57 AM
I'll tell you the even weirder thing. While all (I guess in this case, most) SSes had R7T, not all of them had WU9. I'm not sure what WU9 actually means... any idea? Is it like Y2Y meaning second sticker content?
Is it possible your sticker is just wrong? Can you PM me your VIN so I can check it out? I've actually been working on the '96-'97 SS section on my site the past week, so a look at your car's options from the factory might help me out.
JohnnyBs98WS6Rag
02-11-2011, 12:38 PM
Here's what CompNine's RPO lookup shows:
Option Code First Year Last Year Description
WU9 1976 1981 MOLDING,WINDOW REVEAL WDO R/MLDG(WU9)
WU9 1997 1997 SALES PKG ANNIVERSARY Z28 SS Z28 ANNIVERSARY(WU9)
Z4C is also the RPO for the '97 30th anniversary package, which was also available on "plain" Z28s, not just SSs. CompNine shows:
# of '97 Camaro Coupes w/ Z4C = 3299
w/ R7T = 2474
w/ WU9 = 802
w/ Z4C+R7T = 659
w/ Z4C+WU9 = 802
w/ R7T+WU9 = 659
:confused: Something doesn't seem to add up here. But then again, CompNine reports that R7T is "unknown" and WU8 was the RPO for '96-'97 SS (which I know is not correct).
Xsta Z 28
02-16-2011, 11:41 AM
Per Dave Hamburger . . .
WU9 = 30th Anniversary Camaro SS Appearance and Performance Sales Package
My build sheet:
http://i16.photobucket.com/albums/b28/shudbdrwg/1997%20LT4%20Camaro%20SS/IMG_2472111.jpg
My RPO tag . .
http://i16.photobucket.com/albums/b28/shudbdrwg/1997%20LT4%20Camaro%20SS/IMG_2436.jpg
Brangeta
02-16-2011, 06:59 PM
Let's get down to serious business and see if we can solve this issue Xsta by putting our heads and information together...
Production records are full of problems, so this is going to take awhile to go through.
Let's compare some total 1997 production records.
Compnine has 57,810 '97s are in their system.
Camaro White Book says 60,202 were made.
Camarosource says 58,152 '97 Camaros were sold, but states that industry trade journals say 54,972 were produced for the US market. No record for other markets.
I'm not a data cruncher for GM and never have been, but I personally believe a lot of problems with calculations lie in percentages being used. You'd see things like "71.5% had automatic transmission" and people would apply that % to a total number and come up with an amount that could be off by several cars. Whose records are actually accurate? I don't know, but I like compnine's since it's based on VIN #s. I didn't used to like it, but I like it now. Cars that were not given VIN #s, which could be test cars that were never sold to the public and were crushed when they fulfilled their purpose are not included, so I feel their numbers to be as accurate as we'll ever get. Other issues could have messed with the numbers as well, which I'm not even going to attempt to get into at the moment.
Conclusion: none of the numbers actually match up and it's hard to know what's truly accurate.
Let's work on '97 30th Anniversary SSes now...
Here's the definitions I have:
Z4C = APPEARANCE PACKAGE 30TH ANNIVERSARY
WU9 = SALES PKG ANNIVERSARY Z28 SS
R7T = CONTROL SALES ITEM NO. 44 (Camaro White Book defines it as "SS Package (non-Chevrolet modification)")
I have a SLP Information Bulletin for the '96 (not '97) SS reproduced by a magazine called Camaro Enthusiast (September/October 1995 issue) and it says...
What specific Z28 options are required to order an SS?
1FP87/Z28 (hard-top and t-top coupe models)
1FP67/Z28 (convertible model)
QLC (245/50ZR 16 tires)
GU5 (only required on 4-speed equipped cars)
R7T (specifies SS package)
SS package cannot be ordered with Acceleration Slip Regulation - traction control - RPO NW9
Things might have changed for '97. I don't have that info. Wish I did so I could get some concrete evidence on what WU9 means rather than relying on a definition of it. I don't have much stuff from '97. Most of my physical collection is from '93-'96.
Here's a break-down, and why the Z4C, R7T, and WU9 stuff doesn't make sense. Cars with Z4C & R7T should equal the same number as WU9 theoretically if WU9 truly just means 30th Anniversary SS.
Coupes:
Z4C = 3,299
WU9 = 802
R7T = 2,474
R7T & Z4C = 659
R7T & Z4C & WU9 = 659
R7T & WU9 = 659
Z4C & WU9 = 802
Convertibles:
Z4C = 1,001
WU9 = 264
R7T = 476
R7T & Z4C = 240
R7T & Z4C & WU9 = 240
R7T & WU9 = 240
Z4C & WU9 = 264
Total:
Z4C = 4,300 (total 30th anniversary Z28s and SSes)
WU9 = 1,066 (total 'supposed' 30th anniversary SSes)
R7T = 2,950 (total SSes)
R7T & Z4C = 899 (total 30th anniversary SSes)
R7T & Z4C & WU9 = 899 (total 30th anniversary SSes)
R7T & WU9 = 899 (total 30th anniversary SSes)
Z4C & WU9 = 1,066 (total 'supposed' 30th anniversary SSes)
^^This data suggests that:
1) WU9 ALWAYS accompanied Z4C, (ex: there's not a red Camaro running around with WU9, every single one was white with orange stripes)
2) every single Z4C with R7T has WU9 as well. Why could this be? For '96, R7T was the ONLY code for SS. For non-anniversary edition cars (as far as I know) all '97 SSes have R7T.
3) Not every car with WU9 has R7T, in fact, 167 are like Xsta's and don't have it.
4) WU9 is not similar to the '98-'02 Y2Y code, which suggested second sticker content (optional exhaust and such). Why can't it be similar? Because there are more Z4C, WU9 cars than Z4C, WU9, R7T cars and R7T DEFINITELY means SS for '96-'97.
Okay. So. Let's compare to some published numbers. Published numbers in the past (especially on websites) have NOT always been accurate, but let's use them anyway.
Camaro White Book is the most reliable published source for the public, but it is still full of errors that I'm going to point out. The author wasn't much of a 4th gen fan. He liked 1st gens and it's obvious because he barely breaks anything down, and he either left errors or settled for errors in the 4th gen section. It says 4,533 Z4C were made. This number corresponds with the figure it says for White Leather and White Leather + Houndstooth if you add them up. White Leather was RPO 103, White + Houndstooth was RPO 10C. I'm going to include Z4C in the calculations below to make sure the interior colors are strictly 30th Anni cars and not other colored cars with white interiors (ex: a red Camaro with white leather).
Coupes:
103 = 2,242
103 & Z4C = 2,242
10C = 1,057
10C & Z4C = 1,057
Convertibles:
103 = 726
103 & Z4C = 726
10C = 275
10C & Z4C = 275
Total:
103 = 2,968
10C = 1,332
If you add those two numbers up, you get 4,300, so as far as I'm concerned, Camaro White Book is wrong, and there were only 4,300 Z4C 30th Anniversary Camaros, and only 30th Anniversary models were able to get the white seats (though they were available for most exterior colors in '98 and '99).
Next...
Camaro White Book lists in the Addenda that there were 4,309 30th Anniversary ones... okay... their number changed... and it says that in their break down in this section, another 225 were built for the Canadian market. Well, that's close to true... The RPO code for Canadian equipment modifications is Z49.
Z29 Z4C coupes + Z29 Z4C convertibles = Total Canadian Z4C
145 + 79 = 224
224 of the 4,300 were Canadian. NOT an additional 224.
Next... Camaro White Book says there's 466 Z4C SS hardtops, 241 Z4C SS t-tops, and 251 Z4C convertibles. That totals 958.
Based on my numbers at the top, I got results of 1,066 (Z4C & WU9) or 899 (Z4C & WU9 & R7T).
Camaro White Book disagrees with my calculations again.
SLP had a break out of their records, and surprisingly, I discovered I have this. They did NOT separate the 30th Anniversary cars in their statistics according to a sentence on it, so this isn't all that useful at all. It states 3,038 SSes we made in 1997. That number is way off of what my totals above say and what Camaro White Book says.
SLP says 3,038 SSes
CWB says 3,137 SSes
Compnine says 2,950 SSes
A difference of about 100 between each other.
If I recalculate my numbers and include those WU9 Anniversary SSes that did NOT have R7T, we can get these numbers:
For reference, the math formula would be:
(R7T without WU9) + (R7T with WU9) + (WU9 without R7T) = SS
simplified to R7T + (WU9 without R7T) = SS
Coupe:
WU9 lacking R7T = 143
R7T = 2,474
Convertible:
WU9 lacking R7T = 24
R7T = 476
Total:
WU9 lacking R7T = 167
R7T = 2,950
Potential total SSes = 3,117
Soooooooooooooooooooo, what can we conclude from that?
1) SLP's records, which should be accurate, are actually reporting 79 fewer SSes than actually exist according to compnine's VIN database.
2) Camaro White Book is reporting exactly 20 more than in that database, if you include what seems to be the only two possible ways to end up with an SS (R7T and WU9 cars without R7T = all SSes)
3) Those WU9 cars that lack R7T really are SSes
That took forever. Thoughts? Anybody have any articles, press releases, or similar to back up or refute my claims?
Brangeta
02-16-2011, 07:23 PM
I left a gap in my previous post.
SO HOW MANY 30TH ANNIVERSARY CAMARO SSES WERE MADE?!
That would be these numbers added together:
coupe:
Z4C and WU9 without R7T = 143
Z4C and R7T = 659
convertible:
Z4C and WU9 without R7T = 24
Z4C and R7T = 240
Total:
Z4C and WU9 without R7T = 167
Z4C and R7T = 899
Total 30th Anniversary Camaro SSes = 1,066
Of those 1,066 there were 110 LT4 cars. All were hard tops and had some other limiting options I don't feel like going through right now. I'll go through it on my website at a later date. What I will say is that 106 of those were production ones, 1 was a prototype, 1 was a development car, 1 was a race car, and 1 was immediately wrecked at Young Chevrolet in Dallas, TX and isn't considered part of the production because it was a total loss from what I heard. 6 were Canadian, 100 were American, and then there's the 3 early cars, and the one that no longer exists.
I don't know how many currently exist. It'd be interesting to know since the LT4 Camaros are likely going to be some of the most valuable 4th gens in the future, if not THE most valuable.
If anybody would like to share stories or pictures of these 110 cars, particularly the prototype, development car, race car, or wrecked car, I'd love to see them and potentially include them on my 4th Generation Camaro History site when I'm ready to do the article.
Brangeta
02-16-2011, 07:42 PM
If anybody reading this is still in college, it'd be interesting if you could take advantage of your library's online resources (AKA their expensive subscription to them) and see if you can find a news article from '96 or '97 about the LT4 Camaro being crashed in Dallas, that'd be really neat to share. Some of the databases of old news articles I used to search in college are called LexisNexis, Infotrac, and Academic OneFile. There may have been others. Sometimes they have the text typed up, or even better, black and white scans of the actual articles.
Xsta Z 28
02-17-2011, 10:37 AM
Wow . my head is spinning! . what a lot of numbers to crunch . . .
But interesting info needless to say . . but you are correct it is VERY hard to find the cut and dry "correct" answers . . .
Some of my opinions . .
WU9 is the same as WU8 . . . they = SS. Period. . . the 9 just separates the 30th Anniversary SS from a "base" SS . . . so on the codes a WU9 must have a Z4C (USA) in the list . . I think that is a must and firm answer. . .
R7A and R7T were codes for SLP "stuff" . . . but what exactly I am not sure.
Xsta Z 28
After purchasing my Hendrick LT4 . . I wanted to compile some of the data I received and here is what I compiled:
History of the 1997 30th Anniversary Camaro
1997 marked the 30th year of production of the Camaro, and Chevrolet wanted to commemorate this prestigious anniversary with a unique appearance package for the Camaro. The color pallet for the anniversary package was taken from the 1969 Camaro SS that Paced the Indianapolis 500 race of that year. An unmistakable color combo of white with hugger orange stripes and a white leather interior with houndstooth seat inserts. The interior was further embellished with 30th Anniversary logos embroidered into the front seat head rests, in the center of the rear seat back and on the front floor mats. Chevrolet offered this appearance package on the Camaro Z28 and the Camaro SS.
For the 1997 model year there were only 957 30th Anniversary Camaro SS’s built. Chevrolet designated the RPO code of Z4C to the 30th Anniversary Appearance Package. The 30th Anniversary Camaro SS also required the following RPO codes from Chevrolet; 1SJ (Z28 Preferred Equipment Group #2), WU9 and AG1 (6-way Power Driver's Seat) options for coupe and t-top models, and required 1SM, WU9 and AG1 for the convertibles.
SLP Base 30th Anniversary SS Alterations include:
• 305 horsepower LT1 V8 Engine ( 310 horsepower with Optional Exhaust )
• Lightweight Composite Hood with Functional Forced Air Induction System
• High Flow Air Cleaner Filter
• Rear Deck Lid Spoiler
• White and Orange SS Exterior Badges
• 17” x 9” Arctic White Cast Aluminum Wheels
• BF Goodrich Comp T/A ZR 275/40ZR17 Tires
• Quaker State SynQuest Motor Oil
• Orange Dual Hood, Roof and Deck Lid Stripes
• White SS Car Cover with Locking Cable
• 30th Anniversary SS Cloisonnι Dash Plaque
• 30th Anniversary SS Key Fobs
• Premium Embroidered SS Floor Mats
• Owners Manual Supplement
SLP Additional Content:
• Performance Exhaust System with Twin Dual Polished Tips
• Level II Bilstein Sport Suspension Package (NA Convertible)
• Torsen Limited Slip Differential ( included synthetic lubricant package )
• Hurst Short Throw Shifter
• Engine Oil Cooler
• Performance Synthetic Lubricants Package ( Rear Axle Lubricant & Power Steering Fluid )
• BF Goodrich Comp TA R1 17” Tires ( shipped separately on a second set of Wheels )
Chevrolet Options / RPO Codes:
• 1SA - Base Option Package
• 1SB - Z28 Preferred Equipment Group #1
AU3 - Power Door Locks
A90 - Power Remote Hatch Release
K34 - Cruise Control
T96 - Fog Lamps
• 1SJ - Z28 Preferred Equipment Group #2
AU0 - Remote Keyless Entry System
A31 - Power Windows
DG7 - Electric Twin Remote Mirrors
NP5 - Leather Wrapped Steering Wheel
T96 - Fog Lamps
UA6 - Theft Deterrent Alarm System
• AQ9 - Driver's/Passenger's Reclining Seat
• AG4 - 2-way Manual Driver's Seat
• AH3 - 4-way Manual Driver's Seat
• AG1 - 6-way Power Driver's Seat
• C49 - Rear Window Defroster
• R7A SLP Sales Item #26
• R7T SLP Sales Item
• UM6 - Cassette Player/4-Speaker Sound System
• UL0 - Cassette Player/8-Speaker Sound System (200 Watt Delco Audyssey)
• UN0 - CD Player/8-Speaker Sound System (200 Watt Delco Audyssey)
• U19 - Kilometer Instruments
• U1S - Remote 12 Disc CD Changer
• U73 - Fixed Mast Antenna
• U75 - Power Antenna
• WU9 30th Anniversary SS Appearance and Performance Package
• Z28 Special Performance Sales Package
• Z4C 30th Anniversary Package
• 10I - Arctic White Leather
• 10C - Arctic White Leather w/ Black & White Houndstooth Cloth Inserts
• 10U - Arctic White w/ Hugger Orange Stripes
The Introduction to the 1997 30th Anniversary Camaro LT4 SS
To further celebrate Camaro’s 30th Anniversary, SLP offered to its top dealerships an invitation to order what would become one of the most unique fourth generation Camaro’s ever built: A special content Camaro SS with a 330 horsepower, LT4 Grand Sport Corvette Engine.
Only 106 special 1997 Camaro SS 30th Anniversary LT4’s would be built. 100 would be for sale in the United States and 6 would be sold throughout Canada. Due to timing constraints for certification, the cars were not available for sale in California, New York or Massachusetts.
To purchase one of these special Camaro SS’s one needed to complete a SLP Sales Agreement Form and place a $5,000 deposit with their dealer. Once the deposit was received by SLP, the owner is notified of a production date. The first 50 cars were built between January and February 1997 and the second group of 50 cars was produced between March and April. Production date on HMS #5 was 3/26/1997
The Camaro 30th Anniversary LT4 SS required the following options from Chevrolet:
• Hard Top
• Z4C - 30th Anniversary Package
• WU9 - SS Package
The LT4 SS included all of the base Camaro SS options listed previously and added the following:
SLP LT4 Alterations:
• Second Sticker MSRP of $17,023.00 - On top of the Camaro sticker price
• 330 Horsepower LT4 Engine
• 330 Horsepower Tail Panel Decal
• Stainless Steel Exhaust Manifolds
• Lightweight Flywheel
• High Performance Pressure Plate
• Lightweight Drive Shaft
• High Strength Ring and Pinion Gear Set
• Level II Bilstien Sport Suspension Package
• Torsen Limited Slip Differential with AAM Cast Aluminum Cover
• Engine Oil Cooler
SLP LT4 Additional Content:
• Level III Bilstien Ultra Sport Performance Suspension Package
• BF Goodrich Comp TA R1 17” Tires ( shipped separately on a second set of wheels )
The standard LT4 Engine Specifications from Chevrolet include:
• 350ci Displacement
• 10.8:1 Compression Ratio
• 330 @ 5,800 RPM Horsepower, Factory Rating
• 340 @ 4,500 RPM Torque, Factory Rating
• 6,300 RPM Redline, Factory Rating
• Cast Iron Block Construction
• 4.00 Inch Bore
• 3.48 Inch Stroke
• 282 Intake, 277 Exhaust Valve Duration
• .476 Intake, .479 Exhaust Valve Lift, Degrees
• 46 Degree Valve Overlap
• 2.00” @ 85 grams Intake Valve
• 1.55” @ 75 grams Exhaust Valve
• 3.5 gps, 28 lbs/hr Fuel Injectors
• Cast Aluminum Heads with 2 Valves per Cylinder
• Heads 240 CFM Flow with Higher Ports
• Intake Port Volume 195 CFM
• Combustion Chamber 54.4 cc
• Graphoil with Stainless Steel Fire Rings Head Gaskets
• 7/16” Rocker Studs
• Forged Aluminum Roller Rocker Arms
• 1.6:1 Ratio with Lock Nut and Set Screw
• Oval Section Valve Springs with Higher Closing Force
• Eutectic Aluminum/Silicon Alloy Pistons
• Main Bearings 4-Bolt Centers, 2-Bolt Ends
• Powdered Metal Connecting Rods
• Cast Iron Crankshaft with Undercut and Rolled Fillets
• Roller Timing Chain with Steel Sprockets
• Dual Mass Torsional Damper
• Solid Cam Sprocket
• Heavier Pistons
• Smaller Valve Reliefs
• Balanced Crank
• Rolled Crank Journals
• Wider but Shallower Head Combustion Chambers
• Lighter Hollow Stem Valves
• Positive Twist Compression Rings
• Nodular Iron Main Bearing Caps
• Teflon Rear Main Seal
• Fuel Cut Off @ 6,400 RPM
SLP could have installed the impressive LT4 crate engines directly into the Camaro SS as is, but they took it a step further. All 106 of the production LT4 engines were completely disassembled, balanced, blueprinted and honed with stress plates. Areas of the engine that were checked and adjusted included, the deck, line bore, bearing clearances, head surfaces and a multi angle valve job.
One in 5 engines was selected to be tested on a Superflow engine dynamometer, and if your engine was chosen, the performance sheets were included with the paperwork inside the car. My LT4 Camaro’s engine was chosen for a bench test and the dyno sheet indicated a maximum of 333 horsepower and 344 lb/ft of torque.
Every LT4 Camaro was tested on a chassis dynamometer in addition to performing a short six mile road test, the dyno results were also included with the car and a letter was sent to each purchaser to let them know this testing would be performed on their Camaro. The provided sheets with my LT4 Camaro showed an achieved 281 rear wheel horsepower and 311 lb/ft of torque.
Xsta Z 28
02-17-2011, 10:38 AM
The Introduction to the Hendrick Motorsports Special Edition Camaro LT4 SS
While SLP Engineering performed the LT4 SS upfits they worked with Hendrick Motorsports to take handfull of the 100 LT4 SS designated for sale in the United States and make them just that more unique.
Hendrick placed an advertisement for their special Camaro in the April 1997 Hemmings Motor News publication.
• There are a total of nine Hendrick Motorsports Special Edition Camaro LT4 SS's.
• The 1997 30th Anniversary Camaro LT4 SS's are SLP car #'s 1, 3, 4, 5, 6, 16, 23, 43 and 71 of the 100.
• The #1 LT4 SS was Rick Hendrick's personal car (I believe this car is now in possession of Jim Perkins, former GM General Manager, and the current COO of the Hendrick Companys).
• MSRP was $47,250 - I believe they all sold for over $50,000.
• Changes to the car are mostly appearance
• Embroidered Hendrick LT4 Floor Mats
• Hendrick LT4 Dash Plaque
• Hendrick Key Fob
• Hendrick LT4 & SS Car Cover
• Hendrick LT4 Special Edition Sail Panel Badges
• Level III Sport Suspension
• Came with a short video of them being built at SLP
• Each car was provided with a signed Certificate of Autheniticty
The Hendrick Autogroup owns eight Chevrolet dealerships so each dealership sold one of the HMS Camaros to the public. The dealerships are: City Chevrolet, Rick Hendrick Chevrolet (Durham, NC), Hendrick Automall, Performance Chevrolet, Colonial Chevrolet, Superior Chevrolet, Rick Hendrick Chevrolet (Charleston, SC) and Quality Automotive. My LT4 SS was originally sold from Performance Chevrolet.
HMS # 1 (LT4 SS # 1) Sold From: City Chevrolet Charlotte, NC
HMS # 2 (LT4 SS # 3) Sold From: City Chevrolet Charlotte, NC
HMS # 3 (LT4 SS # 4) Sold From: Rick Hendrick Chevrolet Durham, NC
HMS # 4 (LT4 SS # 5) Sold From: Hendrick Automall Cary, NC
HMS # 5 (LT4 SS # 6) Sold From: Performance Chevrolet Chapel Hill, NC
HMS # 6 (LT4 SS # 16) Sold From: Colonial Chevrolet Virgina Beach, VA
HMS # 7 (LT4 SS # 23) Sold From: Superior Chevrolet Merriam, KS
HMS # 8 (LT4 SS # 43) Sold From: Rick Hendrick Chevrolet Charleston, SC
HMS # 9 (LT4 SS # 71) Sold From: Quality Chevrolet Olathe, KS
Included with the purchase price of the car were travel arrangements and accommodations to pick up the car. The delivery of the nine HMS Camaro SS was to occur at the Charlotte National Speedway but unfortunately it was booked, so the gala affair was held on June 25, 1997 at Hendrick Motorsports Headquarters in Charlotte, North Carolina. The vehicles were arranged around the checkered flag “Winners Circle” center plaza and covered for unveiling by their new owners. Adjacent to the cars were Quaker State Duffle bags and a case of SynQuest Synthetic Motor Oil.
People on hand at the delivery:
• Rick Hendrick
• Jim Perkins; CEO Hendrick Motorsports and former Chevrolet General Manager
• Terry Labonte; #5
• Ray Evernham; Crew Chief
• Chuck Mac; HMS Designer
• Reg Harris; SLP Engineering
• Matt Murphy; SLP Engineering
The new car owners had photo opportunities with the people on hand and had lunch with Rick Hendrick and Terry Labonte.
Jeff Gordon; #24 and Ricky Craven; #25 unfortunately were not available on the actual day of delivery but they did arrive the following day. A few of the car owners had already left with their new cars, so only the new owners that had stayed around for the next day were able to meet them and have their cars signed, if so desired.
Other Info:
• Cars # 7 (SLP SS # 23) and # 9 (SLP SS # 71) are the only two Hendrick Motorsport Camaro SS’s have the optional all white leather, the other seven have the standard white leather with houndstooth inserts.
• The Hendricks crew did not like the exhaust, it was too quiet, but it could not be changed in time for delivery.
• The dual twin tip performance exhaust is interesting, it has extra resonators AFTER the muffler just before of the tail pipes.
• The cars were delivered with a case of Quaker State SynQuest Oil & other QS, stuff - which I currently do not have.
• HMS #4, #5 and #6 were sold to mutual friends from Utah, two have been resold, the other is still owned by the original purchaser.
• Car # 9 (SLP SS # 71) the owner had the outside of the hood signed and clear coated.
• I have made contact with only one other HMS owner #4 of 9.
• At time of the delivery the Hendrick LT4 SS car covers, dash plaque and exterior sail panel badging were not available, and were shipped to the owners at a later date. Cars were delivered with the standard Hendrick SS car cover, dash plaque and sail panel badges.
Breakdown of known RPO code options on the HMS Camaro LT4 SS’s:
HMS # 1 (LT4 SS # 1) Options: 10C,
HMS # 2 (LT4 SS # 3) Options: 10C, R1*
HMS # 3 (LT4 SS # 4) Options: 10C,
HMS # 4 (LT4 SS # 5) Options: 10C, UN0, C49, U1S
HMS # 5 (LT4 SS # 6) Options: 10C, UN0, C49, U1S, R1**
HMS # 6 (LT4 SS # 16) Options: 10C
HMS # 7 (LT4 SS # 23) Options: 10I, UN0
HMS # 8 (LT4 SS # 43) Options: 10C, R1*
HMS # 9 (LT4 SS # 71) Options: 10I
* SLP Additional Content of the R1 wheel and tire package
** The R1 package is indicated on the second sticker, although documented by HMS to be in error.
I own Hendrick Car #5, SLP LT4 SS #6. I cannot take the credit for this information. It has been compiled from information gathered from the documentation included with my LT4 SS, from the former LT4.com, other sources from the internet, friends, former and fellow LT4 SS owners.
Brangeta
02-17-2011, 11:14 AM
I don't have time at the moment to go through things, but from what I could tell yesterday, if you want to get technical, you can't say WU9 is like WU8.
WU8 for the '98-02 SSes was like R7T, it's what all the SSes were supposed to have.
WU9 on the other hand was something only some of the 30th Anniversary Edition white and orange SSes had.
R7A isn't involved with SLP I don't think. I'd have to check tomorrow. I'll look into it; I don't remember what R7A is off the top of my head and I don't want to stick my foot in my mouth. :lol:
Your other posts I'll have to read tomorrow! :)
Brangeta
02-17-2011, 02:01 PM
Okay, had a bit of time before a client meeting on the phone.
R7A definitely doesn't relate specifically to SS, because it was used years before the SS was even available. I checked it for '94 and over a 100,000 Camaros had R7A. In 1997, 44,915 of the 49,515 coupes had it, so it doesn't seem SLP related at all. Even 29,956 of those coupes were V6 coupes and they had R7A.
R7A literally means CONTROL SALES ITEM NO. 26
I have never found a guide to what these control sales item type codes mean. Deciphering them through a process of elimination is just about the only way (other than finding something old that says what they literally mean) and it takes forever, and sucks to do.
I'm going to attempt to figure out if that number is the number I calculated (1,066), just without the Canadian cars included.
coupe:
Z4C, Z49 and WU9 without R7T = 45 (of the 143)
Z4C, Z49 and R7T = 0
convertible:
Z4C, Z49 and WU9 without R7T = 24 (that's right, every single one of these was for Canada (check previous post's number)!)
Total:
Z4C, Z49 and WU9 without R7T = 69
Well, didn't quite get down to that number. According to my calculations, 997 were American (or not Canadian at least) and 69 were Canadian. I don't have the export RPO codes written down at the moment, so I can't check those to see if any were, for example, sent to Japan or Europe. I don't know where the number you have came from, but it seems too low. It might be one of those numbers based on percentage like I mentioned earlier.
Is this really accurate? The '96s were reported to have 300 hp with the Z28 exhaust, 305 with the Two On The Left exhaust. Was TOTL standard in '97 and they are referring to Dual-Dual as the optional one making 310 hp?
Do you have any documentation listing the SLP part numbers for the LT4 or LT1 SSes? I'd love a scan of it if you have anything. I have a very incomplete list.
Do you have the video of the LT4 SSes being built? Can you take a video using your digital camera on a tripod of the TV playing it?
Are you the original owner, or second owner of your car?
Do you happen to have a picture of the R1 tires option on anybody's car or unmounted? How were these wheels and tires delivered? Surely they weren't shoved into the interior of the car were they? I've seen people do that. Only 1 fits in the trunk, two in the backseat barely, and 1 in the front passenger seat.
Xsta Z 28
02-17-2011, 03:16 PM
What I was trying to say is ALL 30th Anniversary SS Z4C Cars had to have the WU9 to become a SS . . . at least that's what Dave told me one time . .
And that the WU9 "forces" the R7T whether it shows up on the list or not . . .
I am the 3rd owner of my car . . . never been titled still on MSO.
I do have the VHS video, and I have a novel of data that came with the car . . which is where a fair amount of the above listed info came from.
I do not recall where I got the power numbers.
I do know the Dual Dual Exhaust was an option in 1997.
As for the R1's I have no clue how they came . . . sure wish mine had them . . . but I assume Hendrick kept them, even though they are listed on my SLP extra content tag . . I do have a letter from Performance Chevy saying they were not included, and listed in error.
MadIceV8
02-17-2011, 05:21 PM
Wow, that is some cool information Andy. Thanks for posting.
Z28/2002
02-17-2011, 05:58 PM
Would be nice if David Hamburger stepped in here
Red64SS
05-10-2011, 02:17 PM
My LT-4 Has the code WU9 , Z4C , and R8T. The build number is 2436 that would suggest the 2nd build of the LT-4 cars. How to tell proof positive?? There are a lot of different "small" things to look for. For a while I was concerned that there would be "cloned" vehicle's out there but there is almost no way to copy every last detail on a Original car.
The best advice is to check on message boards like this one and you will be able to find out quickly if you have found a true LT-4 car.
I purchased my car from Dale Earnhardt Chevrolet and they thought that would be able to get more of them. But we know how that worked out.
Xsta Z 28
05-11-2011, 04:37 PM
My LT-4 Has the code WU9 , Z4C , and R8T. The build number is 2436 that would suggest the 2nd build of the LT-4 cars. . . .
I purchased my car from Dale Earnhardt Chevrolet . . .
Looks like it is LT4 #11.
10I - All white leather
UN0 - In Dash CD
U1S - 12 Disc Changer
R1 - BFG R1 Wheel and Tire package?
Looks like he sold one . . . May I ask are you the original owner?
Brangeta
05-12-2011, 09:48 AM
If I ever find the time I guess I'll have to make a new LT4 registry on my site. Doesn't look like anybody else has interest in making one. Might as well do it. :)
Xlerator
05-12-2011, 09:43 PM
Do it Brangeta
LeanPocket
05-26-2011, 08:51 AM
did u find out if it was a true lt4 or not? lol il be following this thread:corn:
30thSSDreamcar
06-30-2011, 12:30 PM
I just got my first SS and this was sooooo helpful
Xsta Z 28
06-30-2011, 01:19 PM
Congrats!
Spizmo
07-30-2011, 07:43 PM
Xsta, I just noticed this thread and I am surprised you own one of the 9 Hendricks cars. I also read that you only made contact with 1 owner of the other cars. I will find out more info but a family member of mine I believe he is the owner of #9. He talked about his hood being worth a lot and it would make sense if it was signed. He resides in orland so is very local to you considering there are only 9 made which is why it's surprising. Like I said, I will chime in more when I find out info and will also try to get pictures to share. He said he received a video with his car where a nascar driver took it around the track before it got put in the trailer. If you know names, I will PM you.
Xsta Z 28
08-05-2011, 02:16 PM
Spizmo . . I've see the car in person a few times at the Muscle Car show at Rosemont in the fall . . . . every time I am there no one is at the car . . . LOL . .
It is the one car where the outside of the hood was signed.
MadIceV8
08-06-2011, 02:16 AM
Yep, I've seen this car as well at the same show. Bunch of signature's on the hood.
Teri9672
08-16-2011, 11:14 AM
Tim and I still have LT4 SS #69. Tim actually drove it this past weekend. Been replacing hoses that the rats decided to chew on. Still doesn't even have plates. It now has around 80 miles on her :)
CHIPD
10-31-2011, 09:41 AM
There is an LT4 for sale on autotrader. It has 30k miles on it and they are asking 24900. Looks clean and supposedly has documentation. Just fyi. Unfortunately i already bought a 5th gen and would lose too much to make the trade.
slowpoke96z28
12-05-2011, 12:27 AM
he used to come on camaroz28.com to answer specific questions. idk, if he's ever been on here though.
Roc817
12-23-2011, 11:06 AM
I just bought a '97 Z/28 ! White and orange strips! I hope I found out good things about it! Thanks for this information.
TINAT
05-26-2012, 04:59 PM
We are doing some research to determine the value of our 1997 Anniversary convertible SS SLP. This was very informative and a very good description of our car - down to being 1 of 6marketed in Canada - thank you! One thing I found confusing on the internet is one place said that there was only one M30 for the 1997 model. Ours has M30 RPO Code. Do you know if there is only one?
For the 1997 model year there were only 957 30th Anniversary Camaro SSs built. Chevrolet designated the RPO code of Z4C to the 30th Anniversary Appearance Package. The 30th Anniversary Camaro SS also required the following RPO codes from Chevrolet; 1SJ (Z28 Preferred Equipment Group #2), WU9 and AG1 (6-way Power Driver's Seat) options for coupe and t-top models, and required 1SM, WU9 and AG1 for the convertibles.
17 x 9 Arctic White Cast Aluminum Wheels
Engine Oil Cooler
BF Goodrich Comp TA R1 17 Tires ( shipped separately on a second set of Wheels )
T96 - Fog Lamps
A31 - Power Windows
T96 - Fog Lamps
R7T SLP Sales Item
U75 - Power Antenna
To further celebrate Camaros 30th Anniversary, SLP offered to its top dealerships an invitation to order what would become one of the most unique fourth generation Camaros ever built: A special content Camaro SS with a 330 horsepower, LT4 Grand Sport Corvette Engine.
Only 106 special 1997 Camaro SS 30th Anniversary LT4s would be built. 100 would be for sale in the United States and 6 would be sold throughout Canada. Due to timing constraints for certification, the cars were not available for sale in California, New York or Massachusetts.
To purchase one of these special Camaro SSs one needed to complete a SLP Sales Agreement Form and place a $5,000 deposit with their dealer. Once the deposit was received by SLP, the owner is notified of a production date. The first 50 cars were built between January and February 1997 and the second group of 50 cars was produced between March and April. Production date on HMS #5 was 3/26/1997
Hard Top
WU9 - SS Package
Engine Oil Cooler
BF Goodrich Comp TA R1 17 Tires ( shipped separately on a second set of wheels )
350ci Displacement
4.00 Inch Bore
3.48 Inch Stroke
2.00 @ 85 grams Intake Valve
1.55 @ 75 grams Exhaust Valve
7/16 Rocker Studs
Solid Cam Sprocket
Heavier Pistons
Balanced Crank
One in 5 engines was selected to be tested on a Superflow engine dynamometer, and if your engine was chosen, the performance sheets were included with the paperwork inside the car. My LT4 Camaros engine was chosen for a bench test and the dyno sheet indicated a maximum of 333 horsepower and 344 lb/ft of torque.
slowpoke96z28
05-26-2012, 07:30 PM
i would imagine maybe five or ten would have been M30s. i'm sure someone here knows certainly. if not, someone on camaroz28.com can link you with the people who would have been there at SLP when it was all going down...
9cobra4
03-19-2013, 11:19 PM
I'm new to the F-body scene. If I were to post my vin in here could you tell me exactly what the car is? I've read this page and haven't really saw anythig that would answer my question. Thank you so much guys!
2G1FP22POV2153777
1961ba427
03-20-2013, 06:14 PM
2G1FP22POV2153777
Your car is a true LT1 SS....green in color. You can call SLP with the VIN and get your build number.
Need_a_Camaro
03-21-2013, 10:31 AM
I have a very long list of very bad things I'd do to get my hands on an Anniversary LT4 SS. What are they going for? Although, I cant imagine them coming up for sale often.
frankzlt1
03-26-2013, 08:38 PM
A lot
Douglas Kreie
04-11-2013, 11:27 PM
I have recently traded my 2002 buell s3 thunderbolt for a ss Camaro 1997.
I later found out its a slp/ss called slp and gave them vin and they told me it was car #1089. I was so excited! I work at a chevy dealership in Oklahoma. I ran vin and checked rpo's and its truly and SS/SLP got stickers
in both doors and under hood. bike was worth 3750$ and now I find out this could be worth a lot more. I have fixed all little this wrong with it. and had a new paint job on it but didn't know before I painted it that it is what it is, luckly I painted it back the artic white but put the new Chevrolet pearl in it and blacked the top between back window and t tops with blue pearl. got a set of 07 Z06 wheels 18" and putting hockey sticks on it. I pinstriped the wheels red have got new style ss emblems red and and Gm emblem like on the doors of the new cars and a Lt1 badge on back.i will post pictures. so is this really 1 of 957 built?
LilJayV10
04-11-2013, 11:36 PM
If you go and change the paint and added other stuff does it matter if its a 1 of 957 built? Maybe I am not understanding the question.
