bad clutch fluid leak?????? help
i was driving around and clutch was getting shorter and shorter and when i got home it was all the way out and i checked the fluid and empty... and then i put some and pumped the peddle and looked under the car and its all poring out of a little slot between the bell housing and the block.....????????
what to do????
what to do????
CTS-V Shifter Sales
Try tightening the bleeder before you remove the transmission. The new stock slave is expensive for our cars. The list price is about $400, but you can find them for under $300 if you know where to get it. You might consider changing the clutch while you are in there. The LS7 clutch kit (including a new slave) is about $700 shipped.
Headers should have nothing to do with the bleeder. Generally they wont just loosen up but I have seen stranger things happen. Just but a wrench on the bleeder and if its tight, you need a slave.
yea when i loosened the bleeder it felt like it was already tight but its hard for me to get a wrench back on it to make sure its tightened again soo..... yea i guess imma just have to take it in and have it warrantied
thanks for the help
thanks for the help
i have the same problem with mine. i have the parts but too cold to change right now. will come out in the spring. it also gives me an excuse to get the tranny rebuilt. good luck
i just dont want to get it fixed and the same thing happen again, but i have all my headers wrapped and they dont get to hot under there and the hose didnt look to close
Perhaps your transmission got jealous that you gave the motor the upgrade so it killed the slave. Now you can give it a new clutch package! j/k Sorry that happened man, sucks having to fix something that isn't for performance.
