Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
04 Z06 pro charger questions.
Old 01-14-2011, 07:16 PM
black04silverado's Avatar
Default 04 Z06 pro charger questions.
my friend has an 04 z06 with a p1 pro charger on it and its the base kit i believe.
my question is where do you get a different pulley at to increase boost
right now hes at 5psi max and hes wanting to be somewhere closer to 10psi.
as the car sits its bone stock with just the procharger unit on it. with a hand held tuner. i know it needs a tune bad his a/f is around 10.5 at wot.
i keep telling him headers and exhaust and a better tune but he wants to change the pulley and get a better tune.
also what power should he be at right now on the 5lbs?
where do you guess he will be on 10? assuming he gets the better tune?
also where do you get different pulleys at ?
thanks guys.
Old 01-15-2011, 07:45 PM
V-seriesTech's Avatar
procharger is a good spot to start for the pulley.
Old 01-19-2011, 04:22 PM
utryd2's Avatar
You can also order pullys from house of boost.
Old 01-19-2011, 09:56 PM
devious's Avatar
A cam and longtubes will also lower psi. take that into consideration when deciding on a smaller pulley. You might run a 10psi pulley(not sure what size) and bring it around 8psi.
