4th dead battery in 4 years... WTF???
Old 01-14-2011, 10:26 PM
DavidGXP's Avatar
Default 4th dead battery in 4 years... WTF???
What gives guys? If I leave my car sitting for more then a week its a no go. This is my second battery! Seriously.. Do I need to buy a cut off switch!
:c onfused:
Old 01-14-2011, 10:27 PM
2005gxp's Avatar
check for a draw, it has to be an issue here.
Old 01-14-2011, 10:31 PM
DavidGXP's Avatar
No dome light, horn or anything lol.
Intake swap is being performed but this time with a modded dod tray! I'll post intake stuff later so ask questions then.. or PM. Yes.. everything is hooked up.
Old 01-15-2011, 02:48 AM
DavidGXP's Avatar
But from where?
Old 01-15-2011, 08:36 AM
monte_with_a_LS4's Avatar
samething has happened to me but im on my second battery but its starting to happen again. my car sat for a week and went to start it and nothing just clicks. replaced the battery and now its starting to turn over slow again
Old 01-15-2011, 08:54 AM
JWMayes's Avatar
You all using red tops?
Old 01-15-2011, 09:40 AM
2005gxp's Avatar
my car sits for a week at a time right now and still starts fine, im using a redtop
AlabamaGuy's Avatar
Gotta quit listenin' to that bump bump while you're doing the intake swap, David.
Old 01-15-2011, 10:11 AM
Ill_Born_ss's Avatar
Well, if ya find it be sure to share... I am officially on my 6th battery, GM has searched dilgently and has come up empty each time. Even replaced all kinds of stuff, even the starter for the slow cranking (found to be drawing over 300amps) assoiated with this battery issue. But the starter was good once removed, but they installed a brand new OEM one this time.
Old 01-15-2011, 10:22 AM
ebdboudreaux's Avatar
Is your alternator not even charging it?
Old 01-15-2011, 10:27 AM
Yep,everything on mine checks out perfect, they even kept it for 2 weeks to try to find anything, even had the guru`s from OnStar check the whole system, nothing was found. They checked even all the harness to see if pinched or damaged, nothing.
Old 01-15-2011, 10:48 AM
DavidGXP's Avatar
I have noticed that my volts read between 12.8 to 14.6 while driving. Maybe its time for a new alternator? I know I have a draw too, and it might be onstar. My DVD/Nav runs a lot with the key off. Car has only been slow to turn over a few times and I have never experienced dim lights or anything when my voltage drops.
Old 01-15-2011, 10:50 AM
DavidGXP's Avatar
dooh!
I hate doing maintenance. Takes away modding money!
Old 01-15-2011, 11:03 AM
Every wire,relay module,wake to sleep mode even the 17 hr cycle has been checked, verified. No dimming of lights or strange flucations either. On a few occasions I have found a P01639 code for the alternator/regulator but once the batt was dead so was the code. The alternator passes every test even a controlled load test beyond 100amps and back down.
Old 01-15-2011, 11:10 AM
GXP25's Avatar
Now that's what I like to hear.
Old 01-15-2011, 07:37 PM
DP 08 GXP's Avatar
is your nav factory or aftermarket? i have an aftermarket nav/dvd and i had to pull the fuse for onstar because they said at the dealership it was trying to search for a signal
Old 01-15-2011, 09:24 PM
interesting. i have a aftermarket dvd player
Old 01-15-2011, 10:44 PM
DP 08 GXP's Avatar
it killed my battery....luckily i am in good with the shop manager and they replaced it under warranty.
Old 01-16-2011, 01:09 AM
DavidGXP's Avatar
Stock navigation. Intake swap is looking sick. I just need to get my battery replaced and tighten up a few loose ends. Still have posi, gears and valvebody parts to install. Got Nos? Hint.. hint...
Old 01-17-2011, 07:06 PM
hazards280's Avatar
Just had the battery in mine replaced with a red top. Looked to of been replaced once before though. It had a Diehard in it.
