LS1- oil pressure?
LS1- oil pressure?
Can any-body tell me what is the normal oil pressure on a Ls1?, I have a 01 and have 19,000 miles and it reads 5 pounds , And the dealer keeps telling me Ls1 are rated at running at 6 pounds.
Car Is stock, starts up at 40 pounds then after It warms up It (Fluxuwates)from 2 to 6 pounds and stays there.
Is this normal?
Is this normal?
LS1Tech Administrator
Received 1,468 Likes
Re: LS1- oil pressure?
Normal? HELL NO. 2-6psi is unexceptable IMO. I've never seen an LS1 with a healthy motor and oiling system make less that 25psi (warm at idle) with high (80K+) miles, or 30-40psi (warm at idle) with lower miles like yours.
Something is either very wrong with your gage or you have an oiling issue.
Anymore Ideas or thougts,, please keep them comming,
When the oil pressure goes lower than 2 the check gauges comes on so the gauge Is working
I would demand to have that fixed...my car when fully warm at idle is at 40psi, and 60 at crusing, higher at WOT, my 01 motor has 15,400 miles on it....
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by blackssmd:
<strong> Anymore Ideas or thougts,, please keep them comming,
When the oil pressure goes lower than 2 the check gauges comes on so the gauge Is working </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah i have a thought, your car is smarter than your dealer <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> like Bos said demand a new oil pump or something, 2 pounds seeesh thats scary!
Drew
Drew
it's already been stated, but I can't help myself. that is nowhere near normal. You and 40 of your closest freinds, go up to ur dealership and talk engine warranty.
on a more serious note: Demand they pull the engine, take it apart completely and inspect it for wear/tear. Ofcourse they will say no. Contact gm yell and scream at them. Now have the dealership work on ur car as many times as you can. At this point go back to ur dealership, at this point it would be cheaper for them to replace the whole motor than do the labor on it. If they still don't want to play ball, LEMON LAW, get urself a new car. Be very concerned about any damage the low oil pressure might have caused.
Good luck with battling the dealer - there seems to be ALOT of less than honest dealers out there that know there is a problem with the pressure valve of our pumps - call the GM HQ - 1-800# in the owners manual and log a complaint against the dealer and call another dealer - make sure its a pontiac dealer in your area and tell them the problem. Keep calling till you find one that acknowledges the problem and will fix it - call roadside assistance to get the car towed to that dealer free.
Just to make sure I got this right...2 PSI? I imagine with pressure that low, that engine would be knocking like a champ. Is it knocking at all? If not, I'd suspect that the problem may lie somewhere else...like a sender or something. That is just too low IMO for there not to be knock. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ February 26, 2003, 02:40 AM: Message edited by: Jabroni ]</small>
<strong> Can any-body tell me what is the normal oil pressure on a Ls1?, I have a 01 and have 19,000 miles and it reads 5 pounds , And the dealer keeps telling me Ls1 are rated at running at 6 pounds.
Is this normal? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, this is completely normal.
NOT. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I think any chimp should know 2 - 6psi is not normal. So are you saying that when driving around, the oil pressure is 2-6psi or just at idle? Because minimum requirements for oil pressure is 6psi for every 1000rpms. If not met, you may have engine damage. I would have the gauge/sender checked first, 2psi is next to nothing and I think the lifters would fail to pump up. Which would be obvious.
[QUOTE]Originally posted by Jabroni:
<strong> Just to make sure I got this right...2 PSI? I imagine with pressure that low, that engine would be knocking like a champ. Is it knocking at all? If not, I'd suspect that the problem may lie somewhere else...like a sender or something. That is just too low IMO for there not to be knock. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong>[/QUOTE
Yes It Is knocking, I had my oil changed twice In the last 400 miles, still no differnce.
if your motor is knocking and the Techs at the
GM dealership say that the oil pressure is normal
you need to call GM directly and DEMAND a new engine, the dealership is responsible and liable
at this point for the damage that has occured.
My motor has 88k miles and my needle flickers a little but,.....it is around 40 PSI
Yes you have a major problem with that engine. My engine blew after having some low oil pressure issues (sitting around 10psi after warm up), even with a new oil pump. It was consuming a hell of a lot of oil in the end. Like everyone has said, take it back and demand that they tear the engine apart and find out what's wrong.
man .mine"s about 18 to 20 @idle, and im gonna go to a ported oil pump ( dont want to take chances! ) my car went to the :check gauges/no oil pressure/ and knocked like a son of a bitch. there was a cam filing in the oil pump. after h/c so no warranty. and my motor was shot. it was a good excuse for a stroker <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> but not a good experience. DO NOT TAKE THIS LIGHTLY YOU HAVE A REAL PROBLEM!! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Seems like I can add to this and say I have 0 oil pressure. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> My car was started and idled fine with oil pressure around 40-50psi(ported pump) Then about 10mins later I started it up again and the check gauges light came on. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> the oil pressure was at 0. So it looks like another oil pump or pressure unit for me. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
id take that thing and do some serious and i mean serious sperited driving. then when everything fuses itself together have toed to the dealer.lets see them say its normal then.what ******! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by last of the Z28's:
<strong> id take that thing and do some serious and i mean serious sperited driving. then when everything fuses itself together have toed to the dealer.lets see them say its normal then.what ******! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I like your attitude! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
The same crap happened to me when I 6000 miles on my SS. The dealership said that there had been a recall on the oil pump, yet they neglected to tell me that the other times I had been in the shop. Anyway, they tell me that the lifters had gone bad and that that was the cause of the knock. They told me that they would rebuild the engine and see if that fixed the problem. Needless to say, upon hearing this I hit the roof. I told them that they could do this and that I would run the damn thing so hard that it would break again. Well, after my assault of profanity they saw things my way and just replaced the whole damn engine. For God sake, z-28s and ss's are made to run like bats out of hell not for getting the kids from soccer practice. Ever since then its always been yes sir, don't worry sir we'll take care of that for you. Bottom line. DON'T LET THE DEALERSHIP DICK YOU OVER! This was before any mods mind you. Good Luck <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
