cc306 on stock bottom end?
Old 01-15-2011, 02:21 PM
dash94vert's Avatar
Default cc306 on stock bottom end?
Well im gathering all the info that i could to get familiar and ready for a cam swap and LE1 heads, by reading all of the reviews watching vids and numbers being put up with the cc306 and head work, im impressed but not certain if this is on a stock bottom end or not. im new to all of this and i know the cam guide sticky doesnt recomend it but i just want to know can this be done and make good numbers with a stock bottom end and full bolt ons?
Old 01-15-2011, 02:28 PM
myltwon's Avatar
it can be done and has been. some guys have put up some nice numbers with it and times. although if you're buying the cam new why not just have lloyd spec you one for basically the same cost since you're gonna run his heads?
Old 01-15-2011, 02:37 PM
dash94vert's Avatar
that is my plan if i dont find a used cam online. im on a college students budget so im trying to search for a few deals on a cam at the moment lol, thanks for the response
Old 01-15-2011, 02:39 PM
93v8clone's Avatar
dollar for dollar ya cant beat the h/c pachage that loyd does . that and there tried and true
Old 01-15-2011, 02:42 PM
dash94vert's Avatar
and ive done most of my homework on this but what are some good parts to complete the swap such as lifters, valve springs, roller rocker, etc?
Old 01-15-2011, 02:48 PM
myltwon's Avatar
stock lifters are fine as long as they are functioning properly, if not replacement LS7 lifters are the next option imo.
valve springs, I run the crane 10308 kit but I don't know if it's even still made.
roller rockers, I have cheap SA ProForms that work for my application but most will agree that a set of NSA rockers with guideplates and good pushrods is your best bet.
Old 01-15-2011, 03:31 PM
marc97taws6's Avatar
As others have stated, if you are looking at LE1's, you should talk to him about all the custom cam accommodating valvetrain and whatnot. Even if you find LE1 or LE2 heads used, I'm sure he'll help you out with doing a custom cam or helping you find the correct parts to use with it
Old 01-15-2011, 03:49 PM
T/ALT1's Avatar
I ran really quick a couple years back with a similar setup, 355" LT1 (bored .030 over), LE2's/CC306, longtubes, 3500stall, stock M6 3.42's in the 10bolt, in my car a few years back. I was able to run 11.20's@120mph N/A and low 10's@133+mph with 150HP N2o. I am also looking to sell my newer LE3 heads for $900+shipping. LMK Later Clint
Old 01-15-2011, 03:58 PM
LSWHO's Avatar
The question is can you run well with the CC THREE OH SIX CAM. He didn't ask what cam he should run according to ls1tech.
Of all dyno graphs I've seen with the 306 cam it runs out of breath in the 6200 RPM range. Most agree on 6500 being the safe limit on stock shortblock.
This means yes, you can run it on the stock bottom end most of the time. A built bottom end certainly helps if you want to spin higher safely.
I spin mine to 6500 on the reg.
Old 01-15-2011, 04:15 PM
Resident Racing Jerk
vtec's Avatar
do the cc306 and a 150 shot.
Old 01-15-2011, 04:20 PM
LSWHO's Avatar
Vtec, how high do you spin that shortblock of yours?
Old 01-15-2011, 04:29 PM
vtec's Avatar
i shift alot sooner than you do, and very seldom run the 1/4 which the car is setup for.
Old 01-15-2011, 07:35 PM
deviladvocate's Avatar
thats the set up im using, cc306, stock heads, stock bottom end, Pacesetter LT's and ORY with 3" magnaflow catback, patriot .650" lift spring kit, 1.6 rr, ls7 lifters, HD timing chain set, 58mm tb, tune by PCM's for less, hughs 3000 stall, 4.10's, and the nitrous express mainline 2000 kit jetted for 150. i spin my stock bottom end up for 6500 with no issues, the cam peaks right around there. never see any problems spraying the 150 either.
pretty solid set up, but like what the others have said LE has some nice set ups, and AI also has some nice set ups for H/C combo's. look into packages, its a lot cheaper than parting this **** together, trust me lol
Old 01-15-2011, 08:13 PM
dash94vert's Avatar
lol well i found brand new le1 heads from robsquikz28 he seems to always have brand new LE heads for a smaller deal, and also a used cc306 which would be less then a package. i plan on still calling Lloyd so i could have a professional opinion on what im doing and fo a good st up. but thanks for these responses help a lot!
on a setup such as this what kind of pushrods and valvesprings would you guys run?
Old 01-15-2011, 09:20 PM
93v8clone's Avatar
if there l/e heads now most of the time he has good springs in em anyways . just call him an see what they are and have em checked . as far as p/rods go are ya goin with a self align rocker orrr a guide plate setup?
Old 01-15-2011, 09:25 PM
Lawhead's Avatar
Llyod is a great guy and helps everyone even the dreamers
Like me........
Old 01-15-2011, 10:37 PM
hitmanws6's Avatar
Patriot Golds and Comp or Trickflow hardened pushrods. That cam will be fine, people are running bigger than that on stock bottom ends
Old 01-15-2011, 10:41 PM
dash94vert's Avatar
im going to run guide plates most likely, and i pm'd the guy he said hey would need vavle srings of my choice
Old 01-15-2011, 10:52 PM
Village Troll
SS RRR's Avatar
The 306 cam was a successful stable for many f-bodys dating back to the early 90's. With GTP heads and 306 cam it was not uncommon to see mid to low 11's at 117 to 120mph.
Old 01-15-2011, 11:48 PM
riceburnerZ28's Avatar
Off topic a bit but just how old is the 306 cam?
Quick Reply: cc306 on stock bottom end?
