Idles high for 15 second every time i put it in neutral. help?
Old 01-15-2011, 02:28 PM
larson99's Avatar
Default Idles high for 15 second every time i put it in neutral. help?
ive got a 97 t/a and every time i put it in nutural comeing out of any gear or any speed and even when im stoped it will idle at about 2000 rpm for about 15-30 seconds then it will die down. ive already cleand the throtle body out and it wont stop. any suggestions??????
Old 01-15-2011, 11:45 PM
RamAir95TA's Avatar
You need to monitor your IAC counts and have the PCM scanned for codes. Also check for vacuum leaks prior to the throttle body.
Old 01-15-2011, 11:48 PM
MichaelWade's Avatar
After I cleaned my TB I screwed up my IAC, it would idle at 2000+ rpm but after a few hours of driving it would die down. Your's could be on the out, or vacuum leak.
Old 01-16-2011, 12:36 AM
hitmanws6's Avatar
Clean your IAC too. I took mine out a while back and was amazed how dirty it was
