LT1 vs. LS1 tan interior?
Hey guys, i got a quick question for ya. Were the tan interiors outta the lt1 cars a different shade than the ones that came in the ls cars? It looks a little darker from the few pictures ive seen, but maybe its just the lighting or the camera. Thanks
Sick, thanks guys. So here is the panel in question:
The seller says it from a '96 TA, which should be the same color tan as my '02. What do you guys think? The only thing is that i would have to swap over my armrest, and the bottom part cause mine is ebony not grey. Has anyone tried that before? It looks like the parts are just held on by the plastic being melted there. Maybe i can cut the melted part off then put it back together with some screws and washers. Thoughts...
I had an all tan interior, much like what you're describing.
Here's my door panel for instance:
Granted, that's pre-ebony swap.
I've since swapped everything to ebony in my interior.
With those Sonic welds for the armrest, you need to cut the smashed plastic cap off the back . I try to cut the smashed weld off as clean as I can because when I reattach the armrest I epoxy the posts on the armrest and epoxy the smashed weld piece back on . The best possible way to re-attached , would be to weld it back together with a plastic welder( using polypropelene weld rods ) , thats if you have access to one. Buying one, just for this project, would be pretty pointless when the epoxy will work fine . Make sure you use a plastic weld epoxy . The general use epoxys arent gonna work to well on the low energy plastic( polypropelene) GM used on these door panels .
Thanks alot LT4, i think im gonna go for it and try out what you said. Unfourtunatley its an auction on ebay, and theres only a few hours left so i cant really confirm if its a neutral one. But after looking at the pic that fbodyrs96 posted im pretty certain its the neutral and not tan. The good thing is that its not cracked, and he's selling the panel cheap too. Atleast itll give me a little project to do. Thanks again everyone
