ms3 cam head choice?????????
Old 01-15-2011, 10:18 PM
badazz99ss's Avatar
Default ms3 cam head choice?????????
Hey wussup guys im looking for a set of heads that I can make about 450-460rwhp with. So far I have done to the car is ls6 intake,ms3 cam, longtube headers, o/r y pipe, corsa exhaust, ported tb, 3.73 gears, 125 shot nitrous. Im switching intakes to the bbk ssi intake here in about a month but im looking for a set of heads that will get me to about 450-460rwhp with the timing tooken out for the nitrous. Help needed. Thanks guys
Old 01-15-2011, 10:37 PM
garygnu's Avatar
TSP PRC 215/227 CNC heads should work.mention the cam when talking to them.
Old 01-16-2011, 12:20 AM
GT_EATR's Avatar
X2..Please.
Old 01-16-2011, 10:00 AM
98sscammed's Avatar
X3. Was thinking 2.5 243's from tsp
Old 01-16-2011, 10:25 AM
badazz99ss's Avatar
i was thinking about those but I think for the money trickflow as cast 220 heads would make alil more power than the tsp 2.5 ls6 heads.
Old 01-16-2011, 11:42 AM
NBM99SS's Avatar
Some ported 243's of sorts. My buddy has ported 5.3's with MS3 and I always seem to pull on him a bit. I just have PRC LS6's and MS3
Old 01-16-2011, 01:07 PM
badazz99ss's Avatar
what power did you make with the ls6 heads and ms3?
Old 01-16-2011, 02:24 PM
znate's Avatar
I have an 02 z06 with an ms3, prc stage1 ls6 heads and ported fast 90/90 that made 469-415. I dont think you can run the stage 2.5 ls6 heads with an ms3 without flycutting, the bigger valves will hit.
Old 01-16-2011, 04:06 PM
StormesRacing001's Avatar
If I dont like my Tsunami cam, I think I am going to swap in the MS3 with my 2.5 LS6s
Old 01-16-2011, 07:48 PM
TurboStangJON's Avatar
I've got PRC 2.5 5.3 heads and they seem to do pretty well. Car ran 11.01@123 last week with a small 3600 stall and that was at 3300 pounds. The car made 429 with the converter unlocked through a 12 Bolt with 4.10's. I could have spent more and went with a better head but I like them because they were cheap and effective.
Old 01-16-2011, 10:27 PM
garygnu's Avatar
impressive great ET Turbostang ,the OP should copy what you did.
Old 01-16-2011, 11:57 PM
Thanks! Hopefully I will come home with a 10sec timeslip this weekend.
Old 01-17-2011, 11:01 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I think it depends a lot on your budget. The best set of heads we can offer for that cam would be our 215/227 aftermarket casting. Aftermarket casting heads offer a thicker deck so you have more clearance to work with as far as valve size and combustion chamber size.
I ran our stg 2.5 MS3 heads with the MS3 and I thought it worked out great. I had great driveability and gobs of power when I needed it. Our stg 1 LS6 heads will also work but I prefer to see people run the 5.3l heads. The smaller runner and combustion chamber really stretch out the low end power on that cam.
Old 01-17-2011, 01:06 PM
John, I originally was going to do an LS6 head per many peoples recommendations but when I spoke with you on the phone you pointed me to the 5.3 head. Needless to say I'm 100% satisfied with that advice and never got to thank you. My MS3/5.3 head combo works great and has tons of power on a small budget.
Old 01-17-2011, 05:07 PM
I'm glad to hear you are satisfied with the suggestion, and you are running some great times for the setup. I think a lot of people over look the 5.3 casting because of the name but once worked over they work really well for some of these larger cams on a budget.
Old 01-17-2011, 05:47 PM
PREDATOR-Z's Avatar
With a cam as big as MS3 he should be trapping 126+
Old 01-17-2011, 05:59 PM
I'm hoping to loosen up the converter because I'm shifting the car at 6600 and it's dropping to 4900. I think once I get a better converter the times/mph will increase.
Old 01-17-2011, 07:15 PM
badazz99ss's Avatar
well all that being said I think im going to try the 5.3 heads and see where i get. Will I have any room for milling with that head?
Old 01-17-2011, 08:23 PM
I would give TSP a shout and have a long talk about your choices/combo. Didn't mean to get off topic and I hope everything works out for your build.
Old 01-17-2011, 08:49 PM
mred's Avatar
215-225 trick flows...
Quick Reply: ms3 cam head choice?????????
