How important is suspension!!!!!
Old 01-16-2011, 10:29 AM
shaq_2500's Avatar
Default How important is suspension!!!!!
I have an 96 camaro with an lt1 396 in it and my goal is a 10 second street car. i was wondering if anybody doing this with no suspension help. Of course i have nitrous on it. just thinking is this possible. Let me know what yall think.
Old 01-16-2011, 10:31 AM
David21's Avatar
IMO suspension is the first thing you need.
But I build from the bottom up, being sure to have a stable platform to pit the power in.
Old 01-16-2011, 11:59 AM
RamAir95TA's Avatar
I went from 1.55-1.57 60' times footbraking with ET streets to 1.43 60's with a complete UMI/QA1 front end and a drag radial. No other changes.
Suspension is where it's at.
Old 01-16-2011, 12:17 PM
AChotrod's Avatar
Suspension is just as important as HP
Old 01-16-2011, 12:24 PM
defaultexistence's Avatar
completely unimportant on hovercrafts ,boats,UFO's and trees
Old 01-16-2011, 01:09 PM
MasterTomos's Avatar
Depends how important traction and handling is to you? For a 10 second car, I'd definately get out the check book...bolt on cars net gains with suspension...
Old 01-16-2011, 01:29 PM
Zmg00camaross's Avatar
Mine car I been building from the rear forward. Suspension is key.
Old 01-16-2011, 05:11 PM
x2 ...just getting around to internals ...a year of suspension later
Old 01-16-2011, 05:47 PM
3DFORMULA's Avatar
My sig. pic is an exhaust manifold wearing, stock LT1 engine, with suspension only. It is very important
Old 01-16-2011, 06:28 PM
shaq_2500's Avatar
Ok thank u all for your input. This stuff gets expensive real quick
Old 01-16-2011, 08:37 PM
Very expensive, I think suspension is cheaper than HP. and doesn't break well not suppose to.
Old 01-16-2011, 08:47 PM
speed_demon24's Avatar
You need to understand what you are buying does and how to adjust it. Too many people on here keep buying more and more parts and throwing them on the car just to slow down, while others with minimal mods out 60' them.
Old 01-16-2011, 08:54 PM
Resident Racing Jerk
vtec's Avatar
a top fuel engine in a pinto wont run like a top fuel car.
Old 01-16-2011, 09:04 PM
AChotrod's Avatar
Happened to me with non adjustable parts and crappy comp 3way drag shocks on a M6. Never did get the car feeling right after i put those on.
Old 01-17-2011, 04:05 AM
Village Troll
SS RRR's Avatar
SLP Level II suspension with progressive rate springs all the way around, Billstien shocks in rear, Koni one way adjustables up front (rebound only/adjusted full loose), front sway bar still connected, Spohn adjustable T/A, Spohn 25mm rear sway bar, Hoosier 27" QTP's= 1.55 to 1.60 60' times with a dead hook.
The ultimate goal with suspension is traction. Too many like to overcomplicate this by buying **** they don't need for their power level.
Old 01-17-2011, 08:27 AM
iWon's Avatar
Suspension is half the battle man, you need to be able to efficiently transfer the torque to the wheels. Like previously said, stock / bolt on cars will have 1/4 mile gains from suspension mods!
Old 01-17-2011, 08:57 AM
quik95lt1's Avatar
suspension is very important.............i hooked my old 355 HCI setup to a 1.72 60' on a Goodyear Eagle F1 GSD3 stock size 245 tire........suspension is important but whats even more important is how it is set up
Old 01-17-2011, 09:55 AM
Shon Herron's Avatar
Suspension, weight, and Density altitude has more effect on ET/MPH than other mods do!
Quick Reply: How important is suspension!!!!!
