New Camshaft Bolts
New Camshaft Bolts
I purchased these new camshaft boltshttp://www.summitracing.com/parts/ARP-134-1003/. Can they be torqued per gm specs? Or do they need to be torqued per Arp Specs?
Hey, according to the ARP site 8mm 180,000psi bolts are 24 ft.lb. w/arp lube.
I think you'll be good either way.
http://www.arp-bolts.com/pages/techn...orque_us.shtml
I would not use ARP lube in this location. I would Loctite them in place and use the same torque specification since the Loctite will provide similar friction as the lube. A lot of guys have had these bolts back out of the cam. Since you have used the ARP lube, you have to remove the bolts and thoroughly clean both the bolts and the cam threads before you can use Loctite or it will not work correctly.
