Trap Speed after torque converter change?
Old 01-17-2011, 06:11 PM
Old School Heavy
speedtigger's Avatar
Default Trap Speed after torque converter change?
Did your trap speed change after going to a stall converter? How much?
Old 01-17-2011, 09:21 PM
cals400ex's Avatar
my trap speed didn't move much but i dropped 8 tenths in the 1/4. i think mine was less than 1 mph faster with the stall if i remember correctly.
Old 01-17-2011, 09:35 PM
Restricted User
z99ls1's Avatar
What stall did you put in?
Old 01-17-2011, 09:46 PM
a4ls2goat's Avatar
my mph stayed the same...but went from 13.4 to 12.8
Old 01-17-2011, 09:52 PM
FreakishSpeed's Avatar
stayed the same but went from 12.64 to 12.0
Old 01-17-2011, 10:06 PM
Restricted User
z99ls1's Avatar
So why does the mph not go up I wonder? I figured with the light weight and the shift extension it would have to go up?
Old 01-17-2011, 10:11 PM
I need a gauge for that
Atomic's Avatar
Higher stall converters are technically less efficient than lower stall ones, which is why a lot of guys lock them in 3rd.
Old 01-18-2011, 05:53 AM
Old School Heavy
Wow. 6 tenths? I can see picking up 2-4 tenths in the 60', but I would have never guessed 6 tenths.
Old 01-18-2011, 11:04 AM
thunderstruck507's Avatar
Before: 8.3-8.4 @ 85-86mph, 2.0-2.1 60ft dead hooking on street tires
After: 7.85 (let off for bracket race or might have been 7.7)-7.9 @ 87-89mph, 1.79 60ft spinning some on 555r DR
Old 01-18-2011, 11:12 AM
Old School Heavy
Wow. I was not originally planning to buy a stall converter other than the small one that came with my transmission. But, after hearing these testimonials, I can't imagine leaving 6 tenths on the table. Nothing outside of nitrous can give you that much et for that money.
Old 01-18-2011, 11:17 AM
Restricted User
z99ls1's Avatar
I have heard of people droping a full second with a 4000 stall. I still wanna hear more from people gaining mph though
Old 01-18-2011, 12:02 PM
I know right?
And yet everyday there are 3-4 threads on what cam to use for a stock stall...
:b ang:
~$700 minimum to do a cam right with everything for the baby cams 3-4 tenths (being generous I think), have an annoying to drive car, lope and run slow, etc
or $700 converter (mine was $450 used) and $30-50 cooler for .5-.8, launch harder, more fun to drive, not wear out brake pads in a couple months, etc and actually allow you to get a serious cam to make more power
Old 01-18-2011, 12:17 PM
Restricted User
z99ls1's Avatar
Originally Posted by thunderstruck507
I know right?
:b ang:
yep, I agree. A cam without a stall is just stupid
Old 01-18-2011, 01:32 PM
Old School Heavy
My only gripe about stall converters is the way they drive and sound around town.
There are all these posts on here about how their 3600 stall drives just like stock until you get on it. These claims are appearing to be slightly rosey eyed reports. I just went on YouTube and watched some of the videos of guys driving around town in their Yank converters and they sound just like the old slush box converters from back when I was racing. The videos I saw on youtube, you can barely even tell when the car shifts at part throttle. All the gears just run together in one long drone.
Old 01-18-2011, 01:42 PM
I would post up a video but until I get a box to hook up my speedometer it wouldn't do much good.
I have a Trans-Go kit in mine, and did before with the stock converter. At some rpms the shifts sound like they run together but I feel them plane as day.
Driving calm around town I stay under or around 2k rpm accelerating normal unless I'm on a hill, then I get around 2500-2600rpm. I don't consider that bad for a 3600 stall. Before the stall I would be at 1700-1800 for the same things and 2000-2200 for the hills. I was expecting a much larger gap than a couple hundred rpm, so I was pleasantly surprised with how the car drives. My buddy had a Vig 4000 and his wasn't as enjoyable in the least.
My car is also fairly quiet by most gearhead standards so I guess that helps too.
I wouldn't go back. I would drive a civic before I went back to a stock stalled auto...if I'm going to have a slow gutless turd I at least want 35mpg.
Old 01-18-2011, 04:15 PM
Old School Heavy
Post up a video anyway if you would. I will be able to tell by the sound of the engine what is going on.
I am looking at 3 companies right now. Circle D, PTC and Yank. Yank is all the rage on this site, but PTC seems to be the most popular on Yellow Bullet and TurboBuick.com. PTC is nearly 3 hundred bucks cheaper than Circle D and Yank and has every bit as good of a rep, but more in the serious race circles than the street guys.
Old 01-18-2011, 10:06 PM
cals400ex's Avatar
i have a yank PT 3800 2.0 STR
Old 01-18-2011, 10:38 PM
skat's Avatar
No MPH change here. First stall was 3,600 and did drive super close to stock.
Second stall is a 4,000. Does not drive like stock, about 2,000 RPM's to get moving good. But I like it alot more. My car picked up 6.4 tenths with the first stall change and another 2 tenths with the second stall. I pull 1.61 to 1.68 60's everytime.
My car had to lose 200 lbs (mostly the car but 50lbs was me) before it picked up MPH. I am still runing all stock motor just bolt-ons, tune, gears and my stall, car went 11.99 @ 112 last time out.
And I need to change my sig., numbers posted were on stock convertor. My car only put down 321rwhp and 325rwtq on the current stall.
Old 01-18-2011, 10:50 PM
Restricted User
z99ls1's Avatar
You guys are making me lol. I wanted to gain a mph or 2
Old 01-18-2011, 11:06 PM
a4ls2goat's Avatar
who cares about mph....as long as you run s good e.t.
Quick Reply: Trap Speed after torque converter change?
