how do these places that sell engines get the aluminum so clean?
Old 01-17-2011, 07:12 PM
mikezohsix's Avatar
Default how do these places that sell engines get the aluminum so clean?
I'm jealous of how nice all these engines look coming from places like cleavland pick a part. My motor is pretty ugly in comparison.
I'm pulling it for what may be the last time this weekend (fingers crossed, but not holding my breath), and if it's something I can spray on and rinse off, I'd like to do that before it goes in the car....
Old 01-17-2011, 07:23 PM
ebk06's Avatar
They probably get some commercial grade degreaser and a wire or plastic brush and give them a quick scrubbing. I doubt a spray on rinse off product will really work well.
Old 01-17-2011, 07:30 PM
arthropraxis's Avatar
IDK, I think some must paint them for pictures. I have some aluminum control arms that I used several degreasers on and they still look bad.
Old 01-17-2011, 07:44 PM
john 67's Avatar
try some Simple Green
Old 01-17-2011, 08:19 PM
S10xGN's Avatar
Glass bead! I beaded all my loose parts, then taped and tented the long-block and beaded it too...
Old 01-17-2011, 08:20 PM
I soaked them with simple green and white lightening. Scrubbed them with a brush and a wire brush. They still look ugly. They are cast aluminum, and had hot oil sprayed on them after the motor let go which probably explains it.
Old 01-17-2011, 08:57 PM
Tig
Tig's Avatar
Hah, I was wondering the same thing. My block is pretty dirty, needs a good douchein.
I'm going to introduce my pressure washer and some degreaser to my aluminum block and see how they get along, hah.
Old 01-17-2011, 08:59 PM
AronZ28's Avatar
Tried any sandpaper on the aluminum??? That would be my logical step, along with something like aluminum polish you use on wheels.
Old 01-17-2011, 09:20 PM
underdog51's Avatar
Eagle one makes a great wheel cleaner. There is one that works really well but is only used on cast surfaces. Spray on, let sit for 1 to 2 minutes then spray off. Works amazing. It slightly eats at surface so it will dull polished stuff. They have one for polished wheels too, havn't used it yet
Old 01-17-2011, 09:32 PM
Mike52's Avatar
I used this Eagle One Etching Mag Cleaner on my salvage yard engine/trans, it cleaned up very nice. You will probably need to do a little hand scrubbing with a brush on any stubborn, caked up areas. Another great, inexpensive cleaner is L.A.'s Totally Awesome, you will find this at a Dollar General store, it's been discussed as a cleaner on this forum in the past.
Mike
Old 01-17-2011, 10:34 PM
gMAG's Avatar
This works well. Use the metal cleaner first-spray it on, let it sit, rinse it off. My block was stubborn, so I sprayed, then brushed, which did the trick. Then, you can use their wax product which seals in the shine.
You can't use it on 'pot' metal, it'll turn it black.
http://metalwax.com/
This was full of grime, rust, discoloration, oxidation, etc. I used just the cleaner, and not the wax product. It's not perfect, but I'm happy with it.
Here's a couple of more perspectives...
https://ls1tech.com/forums/conversio...ls-blocks.html
https://ls1tech.com/forums/conversio...-question.html
and a caveat...as mentioned by someone in the last link...'be careful what you use on the block, some cleaners will STAIN the aluminum!"
Old 01-18-2011, 10:08 AM
2nd Gen Fl 'bird's Avatar
If you've tried the above methods and still not quite happy, try Dupli-Colors "cast aluminum" spray paint. Pretty impressive for something coming out of a can. Takes just a light coat to get it back "clean" looking. Be sure to degrease.
Old 01-18-2011, 10:17 AM
-TheBandit-'s Avatar
I can also vouch for the Eagle One Mag Wheel Cleaner.
See posts 21 & 22 of this thread:
https://ls1tech.com/forums/conversio...00-6-0vvt.html
Old 01-18-2011, 10:37 AM
gMAG's Avatar
Very comprehensive thread on your Nova, Clint.
The greatest health is reserved for you!
Glenn
Old 01-18-2011, 10:52 AM
Thanks Glenn! I appreciate the complement & well wishes.
Old 01-18-2011, 02:30 PM
kilrcady's Avatar
Eagle one!
Old 01-18-2011, 03:35 PM
hookemdevils22's Avatar
I am a firm believer that glass bead blasters are God's gift to junkyard crawlers.
Old 01-18-2011, 03:55 PM
abot316's Avatar
Powdered Tide mixed into a paste, let it sit, scrub then wash will get you residue free metal
Old 01-18-2011, 04:16 PM
gnx7's Avatar
Eagle One is a sulfuric acid and another type of acid. It will definitely clean just about anything including the skin off your hands. Wear gloves and be careful when using that stuff.
A toothbrush to get in the nooks and crannies and lots of brake cleaner/Eagle One, Engine degreaser will do the trick.
Old 01-18-2011, 04:31 PM
Old School Heavy
speedtigger's Avatar
I cleaned mine with Napa Aluminum cleaner. It works quite well, but if you leave it on too long, it will turn the cast gray like it has been bead blasted. I found you can restore the proper hue with a stainless or brass wire brush. However, I think I will still paint my engine with a custom PPG metallic clear coat. It will give the bright aluminum finish and remain easy to clean where natural finish aluminum will not.
Quick Reply: how do these places that sell engines get the aluminum so clean?
