Oil in the water
Old 01-18-2011, 12:07 PM
Bad Chad's Avatar
Default Oil in the water
Been scratching my head on this one...
I put an LS1 in a 04 GTO about 1 month ago. The car was losing oil somewhere but it was not leaking on the ground and the bottom of the motor was dry. It would lose about 2 quarts a day...
The plugs fouled out pretty quick with oil, I found out I hooked up the PCV system wrong so I just put the LS1 style PCV system on the car and now everything is working great and no longer losing oil.
The car is at a body shop now and when they pulled the Water reservoir off they said the water looked like Jello and was full of oil.
The car never ran hot; it actually ran cooler than what it usually ran...
My question is, how did the oil get in the water? There is no water in the oil...
Old 01-18-2011, 12:09 PM
Bad Chad's Avatar
I do not see it being a blown head gasket or cracked block. If it was then there would be water in the oil when the cooling system pressurized
Old 01-18-2011, 04:03 PM
1INSANEGTO's Avatar
Tttttttttttttttt
Old 01-19-2011, 07:47 AM
Bad Chad's Avatar
Anyone???
