wideband o2 sensor on stock pcm
Old 02-10-2004, 07:00 PM
HotRod68Camaro's Avatar
Default wideband o2 sensor on stock pcm
Would it be possible to replace the stock O2 sensors w/ wideband ones? would they work w/ the stock wireing from trhe original harness? any other comments?
Old 02-10-2004, 10:23 PM
wrencher
wrencher's Avatar
No not even close.
Thats like trying to get your LS1 to run with a ford EEC processor..........
Old 02-11-2004, 07:51 AM
samz28's Avatar
Yes you could disconnect an input line of similar quality, then hack the ecu code to use a targeted air fuel look up table. Easy? no, but it would separate the true ecu haxors from the map editors.
werd.
Old 02-11-2004, 08:10 AM
Moderator
jimmyblue's Avatar
You need the controller box to keep them happy,
without the fine temperature control the output
is worthless. Some of the controller boxes produce
a 0V - 1V output which you could substitute for
(say) the rear O2s. Messing with the fronts is
not going to buy you anything I reckon, the PCM
"is what it is" and expects the dumb, crude,
switching behavior of the stockers. Since WOT
is open-loop anyway, high-performance driving
will still not comprehend any O2 inputs. You have
to explain it, upside, with the laptop.
Old 02-11-2004, 08:25 AM
wrencher
wrencher's Avatar
If you want a W/B go with a controller designed to support it, like a FAST controller.
Alot easier than the alternative if thats what you call it.
Quick Reply: wideband o2 sensor on stock pcm
