02 TA Replaced Radio now Vats is stopping car from starting???
Old 01-20-2011, 06:14 PM
Patsy57's Avatar
Default 02 TA Replaced Radio now Vats is stopping car from starting???
So I replaced my radio and now Vats wont allow the car to start, any ideas what I did or what to do to fix this?
Old 01-21-2011, 07:23 AM
Old Geezer's Avatar
AIRC, the radio has an anti theft device in it???
I remember reading that some vehicles have this, so the thieves can't use the stolen radio in another vehicle...
Not sure how to "program around" this... Someone will respond, I'm sure.
Old 01-21-2011, 09:02 AM
Patsy57's Avatar
Well I reconnected the old radio and it still doesnt start so I`m thinking Vats?
Old 01-21-2011, 10:12 AM
bigboykilroy's Avatar
the radio should not cause the car not to start.
the radio if locked will only not turn on.
Make sure the pellet in the key is clean. clean the ends with rubbing alcohol.
Other than the radio has anything changed?
Old 01-21-2011, 03:00 PM
blade2222's Avatar
dose the security light on?
Old 01-21-2011, 06:32 PM
skypuppy99's Avatar
have you left the key in if you have it will keep adding time to not let it start if its in the vats. pull key and wait 30 mins to be safe. was your factory radio locked? does the light on the dash in def. vent blink? car should start with out radio. how did you power new one? If your old radio was locked car should still start just no radio.
Old 01-21-2011, 08:43 PM
chevymec's Avatar
The radio doesnt effect the starting of these cars. Is the security light on or flashing?
Old 01-21-2011, 09:18 PM
3Camaros's Avatar
Is it a stick car, maybe you knocked the switch off the clutch. Also check for any blown fuses.
If it is VATs the light would be flashing. The light should come on when you turn on the key they go off. You can measure the resistance of the key with a ohm meter, then wire in the same resistance under the dash with radio shack resistors. I have seen a write up on this somewhere on here.
Old 01-22-2011, 02:11 PM
Patsy57's Avatar
So Originally when this occured the car would crank and then stop cranking and the secufity light would come one. Now I have done the resistor method and the car cranks but does not start and the security light is on. So what next?
Patsy57's Avatar
Car is a manual transmission
Old 01-22-2011, 06:53 PM
Patsy57's Avatar
here are some pics of the bypass, the vats is still engaged did I cut the right wire? Believe so
Attached Thumbnails 02 TA Replaced Radio now Vats is stopping car from starting???-2011-01-22_19-48-54_390.jpg   02 TA Replaced Radio now Vats is stopping car from starting???-2011-01-22_19-48-59_707.jpg
Old 01-22-2011, 11:29 PM
chevymec's Avatar
Looks right. How close was the resistance of the key v/s what you put inline?
Old 01-23-2011, 09:22 AM
Patsy57's Avatar
bypass resistance is 9.33, key is 9.56 so it seems its should be right, right?
Old 01-23-2011, 09:50 AM
Patsy57's Avatar
By the way it seems only one headlight comes up now, does that make any sense?
Old 01-23-2011, 07:37 PM
chevymec's Avatar
Im assuming that these are 9.33k and 9.56k? Looking at shbox those should be within spec. Might want to find someone with a scanner to pull any codes.
Old 01-24-2011, 12:41 PM
I like this VATs bypass much better.
I thought the resistance was very pickey like 1% of the pellet value and no start.
but here is the link
https://ls1tech.com/forums/conversio...ts-bypass.html
