Attention: 6LITREEATER... I got a question. :)
I have been debating on buying the AC plate you have with 2 gauges and the vents on the side. Now I have 2 questions before I am ready to buy.. Since the car has 2 vents originally, does the air just come out the 2 sides as normal without have to do anything to the ducts. And the next is where do most people run their wires from off the gauges?? I have never had the bezel off so I'm not familiar with what is behind it.. Thanks ahead of time.
Ryan
Ryan
The factory bezel just pops off and then pops back on. You don't have to do anything to the ducts as they just blow now through the vents in our plate.
Wire running is easy as once that bezel is off you can see there's plenty of places to route the wires from anywhere they need to come from...
Mounting the plate you just epoxy/gorilla glue it in place or (if you want to be able to remove it and go back to stock) you use plumbers strap, bolted to one gauge, looped around the center vent divider and bolted to the other gauge, holds it in place like a bracket.
