Mouser Electronics Part Numbers for Camaro DRLs (Housing and Insert?)
Does anyone have the mouser electronics part numbers to completely replace the whole DRL on an LS1 Camaro? Mine are all burned up, even the housing. I have the gasket and the bulb covered. Basically I would like to get everything after the wires (except the bulb) that go into the housing and everything before the bulb, stopping at the wires that go into the housing. I have some links to pieces that may be correct, but I have no idea if they actually are. I have heard that Camaro and Firebird/TA DRLs are different, but I have no confirmation on that either.
correct insert?
correct housing?
for sure, the correct gasket
Here is a thread that may make visualizing each part of the DRL a little easier.
Thanks in advance for the help.
I searched for burned daytime running lights as well as mouser electronics and didnt come up with anything.
correct insert?
correct housing?
Save the manuals!
correct insert?
correct housing?
The link ^ above no longer works, so I'm attaching the appropriate section from the old catalog, for posterity.
^ Link no longer works, so I'm attaching the actual old catalog for posterity.
correct insert?
correct housing?
