TH200-4R To 5.3L Flexplate Clarification needed
Old 01-21-2011, 10:40 AM
Pro-Tour Heavy Chevy's Avatar
Default TH200-4R To 5.3L Flexplate Clarification needed
Ok I'm getting conflicting info on just what I need to connect my 5.3 with the dished flexplate to my TH200-4R transmission. I already have the regular Torque converter and the GM Flex Plate Spacer and Bolts. Do I still need the 6.0 Flat Flexplate? Or do I just bolt the spacer onto the back of the engine and be done with it. And What about the Hughes Torque Converter spacer, does that require a different flexplate as well. What has worked for you.
Old 01-21-2011, 12:19 PM
Bilster's Avatar
X 2....I would like to have this information also. I've read conflicting advice.
Old 01-21-2011, 12:26 PM
I found this with a little more searching around. Looks good to me.
https://ls1tech.com/forums/conversio...350-5-3-a.html
Tell me what you think.
Old 01-21-2011, 06:46 PM
Old School Heavy
speedtigger's Avatar
You asked this in another thread. Here is the answer that I gave you:
https://ls1tech.com/forums/14393952-post38.html
Old 01-21-2011, 08:17 PM
Bo185's Avatar
If you have the dished 5.3L flexplate the spacer goes on after it and supports the hub of the converter.
Like this!
If you have the flat flex plate put the spacer on first the flex plate.
The flat flex plate has the spacer on the fwd side facing the crank.
Make sure to elongate the holes to match the verter.
Use the spacer to center flex plate to the hub to drill
Old 01-21-2011, 10:37 PM
You know, you are correct my friend and I apologize for the rhetoric, but the following posts state my case on the conflicting info...
Quick Reply: TH200-4R To 5.3L Flexplate Clarification needed
