Need help with stock injectors
I have a pretty much stock 2000 LS1 in a Jeep Wrangler. I deleted all the EGR stuff. The motor just has a custom tune by Howell performance. I have already replaced one stock injector, which was a $100. Now i can tell i have another injector going bad. I don t want to spend $800 on replacing stock injectors. Is there any after market injectors that i can buy that would be close to stock. I know i would have to have it tuned again , and i am ok with that.NEED ADVICE, PLEASE HELP
Also if it makes any difference the motor sat for two years. I think that is why my injectors are going bad.
http://www.corvetteinjectors.com/sho...p?productid=39
why are the injectors going bad? are they simply not working?
if you have a 12V battery and an air tank you could test the injectors off of the car with the rail. all the injector is, is a relay basically and it cycles on and off.
do not buy the factory bosch injector from a stealership. We sell the identical injector brand new for 289 for the whole set of 8
has it had 2 year old gas in tank? if so tank needs cleaned and so does fuel line, new fuel filter also. just my .02 i bought reman injectors for my 99 ta they were 49.95 each with free shipping $10.00 core to ship old back, within 30 days to get core back. cost like $12.00 to ship back.wish i would have seen the sponsor befor bought my injs.
I think that the injectors are going bad from not being run for two years. When i replaced the first injector that went bad. that stopped the missing/popping coming out of the exhaust. now after a couple months its back. so i thought i have another injector going bad. and thought i should just replace all the injectors
"no-brainer"
