CoSpeed
01-21-2011, 05:13 PM
Scorpion LS Race Series Roller Rocker Arms
http://www.scorpionracingproducts.com/images/parts-photos/rocker-arms.jpg
All Scorpion Rockers Feature:
Needle Bearing Fulcrum and Roller Tip, Centerless Ground Trunnion, Centerless Ground Pin & Roller, Burr-Free Thru Hole in Trunnion, Large Machined Seat, Thick Walled Adjusting Nut, Pedestals Machined from Solid Steel, Black Oxide Coated Steel Parts, & 100% CNC Machined. Other benefits include:
• Available in all ratios
• Lightweight for maximum performance
• Easily handle .950” lift and 950 lbs of open spring pressure
• Clear 1.625” valve springs
• Micropolished surfaces finish for maximum durability
• Anodized for additional protection and aesthetics
• Exclusive LIFETIME WARRANTY - all series
• Available ratios 1.7-1.8 Chevy LS engines
• The only ‘No Machining Required’ kit in production
• No changing pushrods, guide plates, rocker studs
• No need for valve cover spacers
Scorpion Race Series Roller Rocker Arms, 1.7:1 (GM L92, LS3 & LS9) [SCP1062] - $503.96 SHIPPED
Chevy V-8 L92-LS9-LS3 - Non-adjustable. No machining required.
Scorpion Race Series Roller Rocker Arms, 1.7:1 (GM LS1, LS6, LS2 & LQ9)
[SCP1098] - $341.96 SHIPPED
Chevy V-8 LS1-LS2-LS6-LS364/400-LQ9 - Non-adjustable. No machining required.
LIMITED QUANITITIES AVAILABLE.
10 REQUIRED DOESN'T MATTER WHICH YOU BUY
DURING CHECK OUT ENTER THIS LINK TO THE THREAD IN THE COMMENTS SECTION AND WE'LL ADJUST YOUR ORDER ONCE IT IS RECEIVED. THESE WILL SHIP A COUPLE DAYS AFTER THE GP ENDS.
END DATE 04-30, 2012
DMH ELECTRIC CUTOUTS
DMH Electric Cutouts are designed to better your cars performance and feel. The cutout works by welding into your stock or modified exhaust. They can be placed anywhere after the headers. To open the cutout you press a switch, which opens cutout, releasing your exhaust. This enables you to bypass your muffler, increasing horsepower and giving your car an extremely throaty rumble.
• Never crawl under your car again to remove the cap from your cutout
• Maintainence free design!
• CNC Machined 6061-T6 aircraft grade aluminum body
• .375 diamiter 316 Stainless Steel Shaft
• Torrington Needle Bearings for years of trouble free service
• High torque gear motor
• Plug and play 16GA. Belden Wiring Harness
• Small black rocker switch is only .75" X .50"
• Proven Design with over 4 years of real world testing
• 4 year replacement warranty!
NO OTHER COMPANY OFFERS A 4 YEAR WARRANTY BECAUSE THEY CAN'T. HOW MANY OTHER COMPANY'S ELECTRIC CUTOUTS HAVE YOU SEEN GO OUT BECAUSE THE CHEAP MOTOR THEY USE?
LINK TO PURCHASE
http://www.coloradospeed.com/index.php?main_page=index&manufacturers_id=500
DURING CHECK OUT ENTER "DMH10" IN THE COMMENTS SECTION FOR THE SINGLE CUTOUTS TO GET $10 OFF.
DURING CHECK OUT ENTER "DMH20" IN THE COMMENTS SECTION FOR THE DUAL CUTOUTS TO GET $10 OFF.
ORDERS SHIPPED FREE. ORDERS WILL SHIP 1-4 WEEKS AFTER THE GP ENDS FOR THE CUTOUTS.
ENDS 04-30, 2012
LINK TO PURCHASE
ENDS 04-30, 2012
