Tap shift conversion
What would I need to put the Grand Prix GXP tap shift setup to my Monte Carlo SS? I know they both have the 4t65e hd transmission, what parts do I need to purchase in addition to the tap shifter assembly itself?
I'm pretty sure the center console is different too... I just don't want to run into any surprises. Anyone know if the linkage is the same?
CenTexSS is correct, the valve body is different, and I also believe there's an extra harness that goes from the PCM/TCM, too.
You'd probably be better off just leaving it alone and using the stock shifter to toggle gears, or just buy a GXP.
