question about oil galley plug,barbel?
im installing the oil galley plug on the back of the motor,is the back of the plug suppose to be flush with the block surface?thanks
stan
stan
To the OP, is this what you mean? I'm running into the same problem
It pretty much stops where it hits the o-ring and the back part of the heads sticks out just a bit of the block. I didn't want to put the cover on until I knew for sure.
Just want to double check. So is this fine then???
