stock 6.0 flexplate
not sure if anyone has actually tested its limits, i was running over 550 RWHP w/o a problem, but switched to a TCI one when i had the trans out
i used the one for a 4L80E, it bolted to the crank w/o the stock .400 spacer, then had a spacer that went bet the crank and converter snout to reg. it(the flywheel had a small spacer already on it)
