blowing thru converter question
Here's my dyno, it's a 4000 vigilante converter spec'd for 500 horsepower, I now make a couple hundred more, is this look like the converter is slipping? In the datalog there is over a 800rpm discrepency between rpm and mph. The green line is the boost and you can see as the boost takes off the graph gets all crazy. No wheel spin.
It says I made 445rwhp with a 383 (ls1 based) with Patriot heads, 224/228 cam, 80mm turbo at almost 17lbs boost.
