08 Sierra Denali 6.2 !!!! comp 401 or 402 cam !!
Old 01-23-2011, 09:13 PM
LT1STROKER's Avatar
Default 08 Sierra Denali 6.2 !!!! comp 401 or 402 cam !!
Ok I have an opportunity to have a cam installed in my 08 GMC truck, and I have to make a decision by Tuesday morning as they start the work on Tusday morning. I am putting a set of milled .030 L92 stock heads with a set of PSI beehive springs, and I have purchased a vararam, intake, as well as a set of headers. I have no intent on a converter right now or gear change, maybe a different exhuast, but I like the tone of the stock denali exhaust, and I know it will get deeper with the headers.
SO NOW THE QUESTION:
I purchased 2 cams; comp 156-401-13 and comp 156-402-13; and only did that because I could not decide on which one, so I will send the one not chosen back, but which one do you guys think for my bolt on truck.
I will also be getting it tuned, for those who were wandering, however I do not know who will be the tuner as of yet, probably PCMFORLESS.
Thanks for your help,
Old 01-23-2011, 10:53 PM
LT1STROKER's Avatar
Anyone have any knowledge as to how the 402 cam works with a stock converter, and how docile it is on the street, maybe with a T/A on a car trailer? That is the only reason I am between the two!!
Old 01-23-2011, 10:59 PM
99bluefirebird's Avatar
Paste in teh specs for each and you will get more help, we are lazy around here.
Old 01-24-2011, 06:53 AM
Coban's Avatar
401 is (214/228 .559/.571) 114 LSA
402 is (218/232 .563/.575) 114 LSA
I chose the 401 for my build because its a heavy truck and I will not put in a higher stalled converter. I also wanted it to sound fairly stock. It's not installed yet though.
Make sure they are installing the phaser limiter as well.
Old 01-24-2011, 09:26 AM
-TheBandit-'s Avatar
Did you check into this when you purchased your VVT cam?
http://www.compcams.com/Base/pdf/156...189%20core.pdf
Hopefully you have a cam matching your phaser pin position.
Old 01-24-2011, 04:35 PM
LT1STROKER's Avatar
i do have the correct phaser to go with the camshafts, and I believe I am going to go with the smaller 156-401-13 cam, unless there is someone who has the 156-402-13 installed, primarily for the same reasons as stated above; i dont want to radical of a cam with so much weight, and having to tow some as well.
Quick Reply: 08 Sierra Denali 6.2 !!!! comp 401 or 402 cam !!
