stealth box pics?
stealth box pics?
was wandering if anyone has pics or a stealth box in either the driver or passenger side of a camaro with a 10" L7 and was wandering on how it sounds. Was plannin on getting a L7 but was wanting to see some pics and hear suggestions before i did thanks.
good luck, ive got a 10' L7 thats been sitting because i cant get a box with the right volume space for the sub to sound right. your going to need a fiberglassed box rather then a mdf box for the size of the cubby hole. ive tried Ian from Keeaudio as he has said he had 2 fiberglass shells but i havent heard back from him anymore. only thing i can suggest is to find a local shop that can fiberglass a box for you.
talked with a kicker tech and they say for a good sound for that size needs to be between .75-1.00 volume. the passenger side one is close as its a half inch deeper so its rated at .70 i think so you could probably get away with that along with some polyfill. my problem is i need a box for the driver side because im mounting the amp on the passenger side behind the plastics to hide everything.
im trying to use the space thats already there rather then having to cut the panel on the passenger side just to still have an open hole on the driver side. trying to even the truck out some, little ocd haha.
Disregard the Punch sub, I'm now using a JL Audio W3 10" sub in the MTX box. By far the best bang for the buck and it sounds fantastic. It will easily rattle everything in the car. I now have a JL 4 channel amp and a Phenix Gold 400 watt mono amp pushing the W3 to wonderful sounding bass, strong and tight.
