should I install this cam advanced? eps 226/230 116+1
Old 01-24-2011, 08:19 PM
crazyelf's Avatar
Default should I install this cam advanced? eps 226/230 116+1
Picked this cam up off here with the intentions of using it as a sleeper cam. It was specd for turbo or blower use. Should I advance it to pick up some bottom end because I will be na. I have a set of milled 243 I planned on installing as well but now I think im going to sell them and go cam only until I can afford a real nice set of ported heads.
Old 01-24-2011, 09:55 PM
airforcemanss's Avatar
i would retod did a few degrees.
Old 01-24-2011, 10:03 PM
99Bluz28's Avatar
If you have a adjustable Cam sprocket give it 2-3 degrees more advance.
Old 01-24-2011, 10:06 PM
*02WS6TURK*'s Avatar
I'm really curious to see how much you gain from the cam. Same one I'm running but on a 114+2 through a M6. I picked up 55rwh on a mustang dyno. Stock 241 heads.
Old 01-25-2011, 02:59 AM
Captain Double Post
BOBS99SS's Avatar
55 rwhp is a pretty solid gain on a mustang,
