VSS question.
Old 01-25-2011, 12:38 PM
supspt454's Avatar
Default VSS question.
Trying to get parts together for this LS1 swap into my 70 Chevelle. I'm running a Muncie 21 and a GM 12 bolt rear axle. I've looked at a few different ideas on VSS. Which do I need to buy that will work on a 98 LS1? Thanks
Old 01-25-2011, 12:47 PM
garys 68's Avatar
Dakota Digital, pass thru for GM. You can still use a mechanical speedo with it. Send the ecu to someone who knows the DD VSS is being used and he can change the pulse per mile to get it in the correct range.
Old 01-25-2011, 12:53 PM
supspt454's Avatar
Hey, thanks alot. I'm new to EFI but thanks to people on this forum, I am quickly picking up the concept. I am excited to get going on this project. Should have the engine setting in the bay this weekend. There is a guy here in Okla that I have been talking with about a reworked harness and PCM. He is out of Midwest City, and looks like good work, and good price...I did talk to a customer of his that said he did good work. Thanks again I'll check out DD.
