Fox Mustang/ LS1/ Air conditioning sway bar fitment?
Old 01-25-2011, 03:10 PM
MeanYellowZ's Avatar
Default Fox Mustang/ LS1/ Air conditioning sway bar fitment?
Just wondering who has done a fox LS swap with air in the factory spot and if they figured out anything good for the sway bar? Factory one hits the compressor, maybe an aftermarket out there that turns downward sooner as the bracket is very near the compressor.
Old 01-25-2011, 08:02 PM
boostnut's Avatar
Subscribed. I've wondered the same thing. Please keep us updated if you come up with a solution.
Old 01-26-2011, 10:03 PM
dmracing's Avatar
Just add some spacers between the bar and mount.
Old 01-27-2011, 09:45 AM
zipster's Avatar
It sounds like you have this set up working, if so, do you have pics?
Old 01-27-2011, 03:35 PM
dmracing's Avatar
No, I dont but some fox turbo kits reqiure it.
Old 10-06-2012, 07:28 AM
TxFireman1972's Avatar
Old post, but I was curious what you ended up doing.
Old 10-14-2012, 10:06 PM
72Elkytpi's Avatar
use the sandon compressor with an S&P bracket it works up high
Old 10-14-2012, 10:16 PM
Forgive my ignorance...S&P?
Old 10-15-2012, 06:05 PM
79LS1FOX's Avatar
Default sanderson a/c mounts
Street and Performance outta Arkansas good stuff but also very expensive!
Old 10-15-2012, 06:13 PM
I found this place too
http://www.lsbrackets.com/view_ls_brackets.htm
Old 10-15-2012, 07:28 PM
LS1PUNK's Avatar
Originally Posted by TxFireman1972
Thats awfully wide, I would get measurements before pulling the trigger.
Old 10-15-2012, 08:21 PM
Yeah I was thinking the same thing. He has measurements. So once I get the motor in I can check.
Old 11-18-2012, 08:57 AM
LS Brackets's Avatar
Default ls engine brackets
Hello guys
I just wanted to let you know this only looks wide. This bracket kit is no wider than the factory Corvette accessory drive.
Way cheaper than most kits to.
I can answer any questions you have just give me a call.
Darrin
Attached Thumbnails Fox Mustang/ LS1/ Air conditioning sway bar fitment?-alternator-stock-pump-spec.jpg
Old 11-18-2012, 09:21 PM
LS1 pwrd NOVA's Avatar
Subscribed
Old 11-20-2012, 11:27 PM
jvert's Avatar
Any updates? I would love to keep the A/C in my ls1 fox swap.
Old 11-21-2012, 08:36 AM
Capown's Avatar
As would I lol!!
Old 11-21-2012, 04:20 PM
Nsty98LS1's Avatar
I believe to use the F-body style A/C bracket, you make a 3/4" spacer to lower the swaybar down. Although I'm not installing the A/C at this time on my swap, I do plan on spacing the swaybar down 3/4" so that I don't have to do later when I do put the A/C on the car.
Quick Reply: Fox Mustang/ LS1/ Air conditioning sway bar fitment?
