Replacing Foglight
Old 01-25-2011, 08:41 PM
cfallsguy's Avatar
Default Replacing Foglight
Does anyone know a part number from Autozone for foglight replacement? Assuming you have to replace the whole housing and not just a bulb on these, correct? Also, any tips for the easiest way to get to the lights or is the only way by taking the bottom panel off to get to it?
Old 01-25-2011, 09:18 PM
NVRBKDN's Avatar
you just replace the bulb. cant remember the part number though. and as for taking it out just a pair of needle nose and maybe a small tip flat screw driver is all i used. there are two plastic (cant thing of the word) pieces on each side that you pull the center out of and then the plastic they sit out and the whole assembly will come out. you have you loosen the adjuster too. hopefully that helps.
Old 01-25-2011, 09:20 PM
battousai's Avatar
excuse my ignorance, but camaro or firebird? lol
Old 01-26-2011, 12:04 AM
cfallsguy's Avatar
^ camaro. And do I need a torx set to get the foglight out from the front? I know to remove the headlights it is needed.
Old 01-26-2011, 11:44 AM
djjab57's Avatar
I beleive its 885
Old 01-26-2011, 11:47 AM
djjab57's Avatar
or h11
Old 01-27-2011, 05:58 PM
zerogravity779's Avatar
Part # 880 on the Trans AM.
$7.99 at autozone. I got one this past Sunday, but I got the 880st ("st" is sylvaina's silverstar bulbs) the one I got was $21.99. They are ALOT brighter. Both my Fog and Headlights are the Silverstar.
Old 01-27-2011, 06:22 PM
djjab57's Avatar
He said Camaro
