New holly ls swap oil pan and swap parts
Old 01-26-2011, 08:17 AM
SUPERBOOST's Avatar
Default New holly ls swap oil pan and swap parts
Any one have the lowdown on the new holly pan yet?How much,is it the one from retro,is it any good,does it fit camaros and novas and all the stuff I love.Looks like they are coming out with some nice ls swap products.I am anxious to see how the swap works as a packedge,engine placement,oilpan clearence,header fit,etc.
Old 01-26-2011, 10:17 AM
69-er's Avatar
Supposed to be the same as Retrolsx's. I wouldn't be supprised if they tweak it a little.
I'm hoping it's at or under Retro's price of $400.
Old 01-26-2011, 11:08 AM
FastKat's Avatar
I am definitely in the market - I want a pan that bolts to my 4L80E!
Old 01-26-2011, 05:45 PM
69-er's Avatar
I've also been looking at the 4th gen F Body pan (F-Pan?). Street and Performance offers one that is modified that will also clear a rack as well as the center link on 1st gen. I think it's cheaper than Holley's but the price they list is with exchange. The core charge looks like around $250. If that's the case then it will be about $500 for them to modify one straight out!
I'll get my buddy to cut and weld a pan if I can find one cheap.
Old 03-11-2011, 03:25 PM
MastMotorsports's Avatar
We have our Mast LS Conversion Pan now available!
Let me know if you have any questions.
Old 03-11-2011, 03:46 PM
bozzhawg's Avatar
Holley LS Retro Pan= $412 retail
Bozz
Old 03-11-2011, 05:02 PM
cookseyb's Avatar
They bought all the equipment from JZ Motor WORKS, I went to their website and it was closed with a note that Holly had bought them out.
Old 03-11-2011, 06:25 PM
ponjohn's Avatar
What?
Do some oil pans prevent using the 4l80?
Old 03-11-2011, 07:05 PM
bczee's Avatar
Some pan do not have the bolt hole or provision for the lower bell housing to bolt up to the old pan like OEM. (some aftermarket pans do and some don't)
Old 03-12-2011, 03:03 AM
holschen's Avatar
You have a perfekt pan ,but we want the transmission to bolt into it
Old 03-12-2011, 12:29 PM
eviltwin_1987's Avatar
why does everyone want to bolt their oil pan to the tranny?
Old 04-05-2011, 01:06 PM
NBM-WU8's Avatar
I spoke with Pace Performance and it sounds like Holley has finally released these for shipment. They should have these coming instock soon. This is what we plan on a using in our '88 Monte. Hopefully it will work ok with the "G" bodies.
Old 04-05-2011, 05:21 PM
firstgenguy's Avatar
The Holley pan is on Ebay for 399 + 25 shipping
Old 04-05-2011, 07:00 PM
LS1MCSS's Avatar
Get the GMPP swap pan. It's not much over $200 and comes as a complete kit.
Old 04-06-2011, 12:56 PM
NBM-WU8's Avatar
The problem I see with the GMPP (Hummer) pan is how much lower than the crossmember it hangs on a Gbody. Perhaps I am wrong though?
Old 04-06-2011, 01:48 PM
LS1MCSS's Avatar
You're talking about the LH8 pan. I'm not. GMPP now has a swap pan.
http://sdparts.com/details/gm-factor...parts/19212593
Old 04-06-2011, 02:15 PM
Earl Filter's Avatar
^^^That is the LH8 pan in a kit form.
Old 04-06-2011, 02:42 PM
bczee's Avatar
The GMPP Muscle Car pan kit does use the LH8/H3 oil pan. It just being refers to it with different names.. same difference !
Old 04-07-2011, 04:46 AM
LS1MCSS's Avatar
Well that sucks. They should call it by what it really is to keep people from ordering it if it won't work.
Old 04-07-2011, 09:09 PM
5.3 cutty's Avatar
ok heres my only issue with finding the right pan for my g-body cutlass.Im running a air ride system and my engine crossmember is about 3ins off the ground. s&p seems to have the only pan that clears the crossmember but is way to rich for my blood so does anyone know if Mast or holleys pan will clear g-body crossmembers????
Quick Reply: New holly ls swap oil pan and swap parts
