Injectors flow rate for 1999 camaro
Old 01-26-2011, 03:40 PM
98hc4mula's Avatar
Default Injectors flow rate for 1999 camaro
I need some help from someone here please.
I have a 99 PCM that is controlling a 6.0 with stock 99 injectors and stock intake. I need to find out the injector scale to input it in the tune. I came up using EC-Tune spreadsheet with a scale from 30.59-33.51 lb/hr
using the value for injector IFR of 26.4, is that the value I need to use or should I use 22 lb/hr since they flow 22 at a pressure of 43.2?
I want to make sure the values are right. the car had some 42lbs tuned into the pcm but now it has the stock 99 injectors.
thank you in advance.
David
