cam install & degree
Old 01-27-2011, 10:34 PM
1toofastlt1's Avatar
Default cam install & degree
Can anyone give me the step by step on how to set up my cam. its a cc305. I already have it installed in the engine but how would i set up the timing gears and degree the cam in?
Thanks
Old 01-28-2011, 01:08 AM
no body installed a cam here? lol
Old 01-28-2011, 01:15 AM
gregrob's Avatar
You probably bit off more than you can chew. Its not very wise to get slam in the MIDDLE of something like this, then start asking people on the net how to do it.
Regardless though: http://shbox.com/ci/cam_install.html
Good luck. Feel free to PM with any specific questions you run across.
Old 01-28-2011, 02:27 AM
NitroFumesAteMyBrain's Avatar
its a doweled camshaft(cant spell).......the only way to change timing would be with offset crank keys. these cams are as simple as they come. no technical degreeing involved.
Old 01-28-2011, 07:14 AM
shbox's Avatar
If you want to actually degree the cam, you can find step-by-step info at most cam supplier's websites. On an LT1 it is mostly used for checking that the cam was ground properly, as most people don't change the cam timing.
Quick Reply: cam install & degree
