C5 Idle Relearn?
Old 01-28-2011, 05:15 PM
Paul 75 L82's Avatar
Default C5 Idle Relearn?
I just installed a Texas Speed 228R cam in my 02 Z06. Everything is great with the motor and I have a date with my tuner Tuesday. My problem is that it will not idle at all. I would like to drive the car around just to let it go thru some warm up and cool down cycles before it hits the dyno Tuesday. I have read about the C5 Idle Relearn by pulling a couple of fuse's. Will that procedure help my idle problem? I don't want to screw anything up before it goes to the tuner but if the relearn procedure would work I would try it just to be able to drive it around some before Tuesday.
Old 01-28-2011, 05:23 PM
vette0009's Avatar
http://vettetrick.com/viewtopic.php?f=34&t=48
Old 01-28-2011, 05:27 PM
T-REZ's Avatar
Originally Posted by vette0009
great info man
Old 01-28-2011, 07:28 PM
So by doing the relearn it won't screw up anything for my tune?
Old 02-01-2011, 01:46 AM
01ssreda4's Avatar
That work for a camaro?
Old 02-10-2011, 08:51 PM
Vexzer's Avatar
Ask your tuner first. I didn't read the other posts about the relearn but the PCM holds learned fuel trims. It takes software to clear those so ask your tuner if he thinks you should clear them and drive the car a while before he begins tuning.
Old 02-10-2011, 09:51 PM
joecar's Avatar
Your tuner will tune it for idle.
Quick Reply: C5 Idle Relearn?
