A very big list!
A very big list!
First off I know this is a very big list but it's what I need and my health is getting better so I am ready to get this thing done. The part numbers are all from jegs and I am not dead set on these brands as long as what I get is this or better. I am willing to buy new from a vender on here but would like to save as much as I can and good used is ok on most of this stuff. Sorry it's so long but like i said it's what I need.
Outlaw Shifter with Cover
4-Speed GM/Ford & TCI 6x Transmissions
2-Button Design
Part Number # 890-611641
SFI-Approved Flexplate
Fits Chevy 4.8L/5.3L/5.7L/6.0L LS1/LS6-Series V8
Dual Bolt Pattern
Internal Balance
168-Tooth
Part Number # 890-399753
Streetfighter Torque Converter
GM
1991-Later 4L80E
Lock-up
Part Number # 890-242940
8-Point Roll Bar Kit
Part Number # 550-944503K
1993-2002 Camaro/Firebird Suspension Kit
Frame connectors
*******Adjustable rear control arms just bought a set from itsjustaSB pay pal sent thanks*******
####Adjustable torque arm----purchase pending local###########
Part Number # 550-40054K
Adjustable Panhard Rod,
1982-02 Camaro/Firebird
Black Powdercoat
Part Number # 550-41056
GS-1 High Back Sport Seat
Black
Part Number # 555-70240
LS1 Aluminum Intake Manifold------ bought local ls6
Satin finish
Part Number # 925-300-111
90mm Throttle Body LS-1/LS-2
Part Number # 510-112-576
High-Flow Mass Air Flow Sensor
2001-02 Camaro Z/28, SS LS1
2001-02 Firebird Formula, Trans Am LS1
100 mm
1998-02 Camaro/Firebird
5.7L LS1
Dual 3.00'' Outlet
5''x10'' 80-Series Crossflow Muffler
3.00'' Stainless Tips
American Thunder Series
Dual Out Rear Exit
Installation Diagram
Part Number # 389-17199
Race Ready 3" Single Cutout Kit
Includes cutout valve, wiring harness, and hardware
Part Number # 815-EC300S
Exhaust Cutout
Fits 3" Exhaust Pipe
Part Number # 815-Y300
Fire Suppression System
#5 FE-36
Part Number # 877-9302
Platinum Series Harness
5-6 Point
Pull Down
3'' Wide Straps
Cam-Lock Type
Part Number # 821-9210CPL
Chrome Moly Black Oxide Hex Head Fastener Kit ----purchased.....
SB Chevy LS-Series
Part Number # 070-534-9805
Chevy/Ford, 7/16'' x 1.00'', Hi-Perf Series
Part Number # 070-100-2801
Heavy Duty Housing and Performance Axle Kit
Chevy Camaro/Firebird
1982-92
With Torque Arm Mount
Part Number # 272-GMF8292X
9-Plus Sportsman Complete 3rd Member - Assembled
Nodular Iron Case
3.50 Gear Ratio
Trac Lock Differential
New 3rd Member Case
Pinion Support
31 Spline
1330 Series Short Yoke
Timken Bearings
National Oil Seals
Part Number # 272-9TL350S
Also I need a cross member for a 4l80
2-Button Design
Dual Bolt Pattern
Internal Balance
168-Tooth
GM
1991-Later 4L80E
Lock-up
Frame connectors
Black Powdercoat
Black
Satin finish
100 mm
5.7L LS1
Dual 3.00'' Outlet
Dual Out Rear Exit
Exhaust Cutout
#5 FE-36
5-6 Point
Pull Down
3'' Wide Straps
Cam-Lock Type
SB Chevy LS-Series
1982-92
Nodular Iron Case
3.50 Gear Ratio
New 3rd Member Case
Pinion Support
31 Spline
Timken Bearings
National Oil Seals
Location: Your girl's back door giving her the long stroke while you're at work
MetallicaMatt has a Safecraft fire system for sale
https://ls1tech.com/forums/parts-cla...ssion-kit.html
