Rods Question?
Rods Question?
Is a 6.125 LS rod any different from a standard 6.125 small block chevy rod?Building a 418 4"stroke L-92.Looking at a set of competition products pro-lites.Cheap,light and good to 800 HP.Any input good or bad is welcome.7/16 arp bolts standard.350 bucks plus shipping.Thanks for any help!!
Yes they are different. SBC rods are offset .030-.035 away from the fillet. LS1 rods are centered on the rod throw. Cylinder bank offset is different on LSx vs SBC.
Depends on piston's pin boss spacing and width on the rod and the piston. The Wisecos for instance are about 1.140-1.150 and the ICR SCAT I-Beams for instance are .960 wide so there is more than .080-.100 on each side so even with some offset you are good. On a rod with a 1.060 wide small end it starts getting much closer. We just do what it takes to make it happy.
Not scat brand.
These rods are made by Competition products,are full C.N.C'd good to 800 H.P and weigh 607g.I am not sure if they make a L.S rod.I am giving you old school small block info.The scats you are talking about are my second choice if they don't make l.s. rods..Thanks
