H/C/I, should I rebuild the shortblock?
Old 01-29-2011, 12:38 PM
FST99Z28's Avatar
Default H/C/I, should I rebuild the shortblock?
I suppose I should start off with my planned list of modifications and let you help me decide if I should rebuild my 99 LS1 76K shortblock . Or would I be fine leaving it alone?
Engine Related Mods planned:
Fast 102mm intake
92MM TB
Fast fuel rails
Bosch Green Injectors
CNC ported 243's w/ 5 angle valve job
Crane Dual Springs
LS2 Adjustable timing set
Custom grind Comp Cam 220/224 .581 .581 112 LSA
Kooks 1 7/8" race headers
Comp Cams Rockers, lifters, and -.050 pushrods.
This is an NA car, I don't plan on spraying either.
I drive it to work occasionally and race at the track 3-4 times a year. I do plan on installing ARP rod bolts.
Thanks in advance for your input.
Old 01-29-2011, 04:19 PM
Darkman's Avatar
A LS1 shortblock is generally considered good for 200k miles if properly maintained and not subjected to abuse such as operation above redline. If you are in doubt run a compression check on it. Otherwise, it should be good to go.
Old 01-29-2011, 06:53 PM
FST99Z28's Avatar
The engine is in great shape, just figured I would get some input. Thanks!
Old 01-29-2011, 07:00 PM
mike c.'s Avatar
Don't bother ti'll she blows.
Old 01-30-2011, 02:30 PM
brooknasty's Avatar
It will be fine leaving it alone, but tearing engines apart and assembling them is just plain fun!
Old 01-31-2011, 09:56 AM
NHRATA01's Avatar
Yeah at 76K you have a ton of life left in the shortblock, I would leave it alone.
Old 01-31-2011, 10:06 AM
98z8uup's Avatar
If taken care of they are good for 200,000 miles ask me how I know.
