The Fastest Bolt On Only LT1's in the World List
Old 01-30-2011, 02:50 PM
CamaroRacing12's Avatar
Default The Fastest Bolt On Only LT1's in the World List
In light of the new "street stock" class at the 4th annual ltx shootout coming up this september 3rd in bowling green KY i figured i would start a fastest bolt on only list just like we have the list in the sticky for fastest lt1's.
so give your name/username, times, year/model car, raceweight, and w/e else you feel like including (DA, track where you made the pass, 60ft, 1/8th, date, etc) I will edit and update the list on a daily basis. and maybe a mod can make this a sticky?
*Just a reminder, bolt ons consist of any mod that dosent touch engine oil except rockers. stock intake required. intake, cam, heads must remain untouched etc.*
1. Tom Cowle - 11.481@118.98 1.502 60', 95 Camaro Bolt-ons/Auto/Fuel Injected "Bolt on Record"
2. John P. (1SlowFormula) - 11.561@118.00, 95 Formula A4, Bolt-ons/NA/2835 lbs "Bolt on Record holder Sep/08 - Oct/08, short lived victory"
3. Shon Herron - 11.805@113.96, 97 Z28 M6, Bolt-ons/NA/3100lbs "Bolt on Record holder 3/26/06 - 09/21/08"
4. Brian Nelson (95z28camaro) - 11.91@111.56, 95 Z28, th350/Ford 9", 3125lbs
5. LSTHIRDGENCAMARO - 11.93@111mph 60ft: 1.52 Rockers, CAI, shorty headers, 3800 stall, stock transmission, stock suspension, stock 10-bolt 3.42 gears, tune, Hoosier QTP drag radials.
6. Tony Quadros (CamaroRacing12) - 11.998 @111.02mph, 95 Z28 A4, Bolt-ons only/3150lbs/BONE STOCK SUSPENSION/BONE STOCK REAR W/3.23'S, Cecil County Dragway, MD. -680' DA. 2011, 2012, and 2013 LTX Shootout Street Stock Champ
7. More Cubes - 12.22@105.58, 7.64@87.31. 94 Z28, TH400/Ford 9", 3250lb. Stock longblock with a carburetor.
8. big_t (aka BIGT94z)-12.251@110.22, 96 formula M6, bolt on's, 4:10's, et streets, full suspension, 3200#
9. roadtrip120 - 12.295 at 112.01mph Bolt-on Record Holder 5-6-2005 /3-25-2006
10. TravisMcGill2000 - 12.326 @ 108.17 with 1.59 60ft, 7.78@86.. Full boltons besides ewp, 3800 stall, 3.42 gear, 3400lb raceweight, 1000 da
11. Muddyjimmy - 12.342 @ 108.41mph w/ 1.61 60', 85 Z28, 3350lbs, Full Bolt On and Suspension, 4l60e w/ SS3600 stall, 10 bolt w/ 3.90 gears. Gateway Motorsports Park 4/23/14 556' DA
12. Pat Gish - 12.365@107.21, 7.799@85.97, 1.619 60', 1996 ImpalaSS, A4/3400/4.10, 3925 lbs Cecil County, MD. -550' DA. B-Body Bolt on Only Record
13. 95z6spd - 12.384 @109.47 95Z/M6 TOTALLY STOCK INTERNAL LT1 ALL MOTOR Best w/15" E/T Street Radials 1.671 60ft3480lbs est., DA -500 est., ***Fastest SI NA 6spd LT1 in the Country*** -311rwhp 347 rwt
14. Celeste Koenig - 12.457@108.20, 7.912@86.29, 1.697 60', 1996 Impala SS, 4L80E/3900/4.10, 4000 lbs Cecil County, MD. on 10-13-08 -1724 DA
15. Matt Haight (bufmatmuslepants) - 12.531@110.33, 8.071@87.98, 1.847 60', 1994 CamaroZ28, M6/3.42, 3225 lbs
Buds Creek, MD. -816 DA
16. ks my ss - 12.54@112.16 w/1.84 60 ft. - 96 z28/ss m6 - 3560 lbs
17. 96silveram - 12.61@109, 8.011 @ 87, 1996 WS6 T/A, T56/3550lbs my best guess/4.11
Tulsa, Ok. (Circa 2000ish) 1200' DA
18. Taner - 12.68 @ 109.8 mph, 1.68 60' - msd coil, 4.10's, borla y pipe, SLP 2OTL, mcleod street twin, et streets out back. back in 10/2001. Lapeer Dragway.
19. John Deere Racer - 12.68@ 108. 1.62 60ft. On stock wheels with BFg dr
20. IllusionalTA - 12.73@109 1.91 60ft
21. Jayme 302 - 12.74 @ 107mph in 2001 in my 1995 Z28 with bolt ons only
22. Frank Griffin(aka-Biggriff)- 12.76 @ 105 with a 1.73 60' 4:10's and a Vig 3600 stall sitting on Nitto 555's (pretty much full weight car)
23. IDriveChevy - 12.77 @ 104 with a 1.66 60'. 8.0 @ 80 mph 1/8th mile. Capitol Raceway in MD.
24. Jeff Faust - 1996 Formula WS6-LT1 - 12.78 @ 108.12 1.885 60ft - lt's, ory pipe, corsa cat back, ud pulley, bbk 58mm tb, matched intake manifold, EWP, STOCK stall, ORIGINAL tranny
25. Ed D./LT1-XJS, 12.821 @ 104.22, 8.187 @ 84.6, 1.744-60', '89Jag-XJS/'93 LT1 a4, 3900lbs.
26. White95z -12.873 @107.55mph 97 z28 m6, headers, lower control arms, panhard bar, subframe connectors, nitto drag radials, stock 3.42 gears. 2000 DA
27. Neil Biswas 1993 Trans Am Vigi 3200, LTs, Borla, MTI CAI, PCM4less Tune 12.88@102
28. David Collins, 1996 formula ,CAI, LTs with dumped magnaflow, PTC stall, stock suspension minus panhard bar, stock tune, 3450 lbs - 12.90 at 103.
29. Matt Plotkin (coolmanvette75)- 12.93 @ 106.41, 1.9 60', -443DA: 94 Z28 M6, LT's, True Duals, DRs, 3.73s, Moroso CAI, UMI Adj. Torque Arm, Eibach Drag Launch Springs, CE Shocks, LCA's w/ relos, EWP
30. JasonShort - 12.94@110.88 (1.94 60ft.), 1993 Formula, M6, 3.23 rear, 1998
31. Rudy(96Lt1m6) 12.98 @ 106,1.92 60',3600'DA. 11.33 @ 117 1.6 rr,SLPlid,pacesetters,X-pipe,flowmaster10s,mad tuner.
32. Duh - 12.99 @ 103, full suspension on 15" dr's, stock engine except full exhaust and ewp, no tune FLT lvl 4 w/3600 stall
33. marc97taws6 - 13.024@103.33 with a 1.74 60 ft 97 LT1 WS6 with Ebay stainless steel LT's and ORY and SLP LM2 catback (ran a little rich), pulley, 3.73's, yank ss3600, torque arm, CE rear drag shocks 2700DA
34. Zlicious94 - 13.0x @ 107x with a 1.9x 60ft - Cai,lt's,exhaust,tune!
35. Luis Morales (fireformula91) - 03/18/2011, 13.08 @ 105, 60ft 1.941, 1/8th 8.404, M6 94 pontiac trans am, 3540 RW, DA 3300 Las vegas
36. Marshall51812 - 1.853 60'', 8.376@79.625 1/8th, 13.124@100.7 1/4, -54 DA @ 662 feet and 52 degrees, 3750lbs
37. Lawhead - 13.22 @107mph LT's, True duals, LS1 Lid, Tune, 3.73s
38. ItSSlowZ28 - 13.23 @ 103 with 1.80 60ft. headers, intake, 3200 stall coverter, 3.42 gears, BFG drag radials, 3660#'s w/ driver
39. AChotrod - 13.3x @ 103x with a 1.9x 60ft, b&b catback exhaust, nitto drag radial, full weight
40. Juice Woodson (Juicelt1z28) - 13.34 @103.99 with 1.9 60ft Headers/K&N Intake/ Exhaust(dumped at rear axle)/ 3.42's/3000 stall, Cecil County Dragway
41. Jeff Zebert (Linkziz) 13.402 @104.47, 2.079 60', 3440 lbs raceweight, 95 Camaro, 93 Lt1, 700r4, stock stall, 4.10s, open rear, 245/50r16 tires, pacesetter longtubes, ORY, Borla Catback, K&N intake, trickflow elbow, SFC, Spohn tunnel mount torque arm, -280 DA
42. Alex Orr (chevymec) 1997 TA 13.43@100.41 1.89 60' A4 Stock internals-Full bolt on's-Mac Mids-Hooker Catback-3.42's 255/50/16 MT DR's Full weight .
43. Beau Novak (The LT1 That Could) - 13.445 @ 103.35 2.01 60'; 95 Z28 A9
44. Marc hudson fad2blk93 13.48 @105.49 1.942 60ft full race weight tb bypass frame connectors k&n cai pcmforless tune lt4 roller rockers 3.73 gears
Old 01-30-2011, 02:56 PM
whytryz28's Avatar
More info on Toms car?
Old 01-30-2011, 03:04 PM
bowtienut's Avatar
Old 01-30-2011, 03:15 PM
Colin91Z's Avatar
Damn thats movin out at almost 4k pounds! Did you run that with the factory b-body iron heads? Or did you swap them for stock aluminum heads?
Old 01-30-2011, 03:17 PM
gregrob's Avatar
Bolt ons are gay
Old 01-30-2011, 03:23 PM
bowtienut's Avatar
The engine was never opened up except the valve covers for 1.6 RR's and valvesprings. To this day it has only 28k miles on it (albeit many of them 1/4 mile at a time!) and is sealed up sitting in a climate controlled garage. The thought crossed my mind to stick it back in the car when I saw the post about the bolt-on class at this year's LTX Shootout, but that wouldn't be in the spirit of that class. We heavyweights used to have some awesome bolt-on class competitions at the big B-body events. Much more closely fought battles than in the modified classes!
Old 01-30-2011, 03:25 PM
bowtienut's Avatar
Originally Posted by gregrob
Bolt ons are gay
Do any of your 2766 posts actually say something of use or of interest to anyone?
Yeah, I can be a dick just like you!
Old 01-30-2011, 03:40 PM
agreeed!!
Old 01-30-2011, 03:42 PM
pat in ur description u said u had 4.10's was that on a 26" tire? if so what rpms where u spinning to to have enough to go through the traps?
Old 01-30-2011, 03:49 PM
lt1-xjs's Avatar
Ed D./LT1-XJS, 12.821 @ 104.22, 8.187 @ 84.6, 1.744-60', '89Jag-XJS/'93 LT1 a4, 3900lbs. 3/09 1580 DA
Old 01-30-2011, 04:13 PM
bowtienut's Avatar
Yes, a 26" tire. I don't remember the exact rpms; somewhere around 6200 with TCC unlocked and 5800 with it locked. That loose 3400 Edge TC was night and day difference from the more efficient Yank SS3600 I later put in it; the Yank dropped only about 75 rpm when I locked the TCC. It would have easily gone better than the 12.36 (at Cecil County, MD) if I had gone back to one of the East coast tracks with it. It was worth a solid tenth at all of my local tracks.
Old 01-30-2011, 04:16 PM
LSWHO's Avatar
I think Track and/or ideally DA should be included as well with these times.
Old 01-30-2011, 04:28 PM
bowtienut's Avatar
Agreed. I've edited my post.
Old 01-30-2011, 04:29 PM
Black1995Z28's Avatar
Holy crap 11.4 with bolt ons
Old 01-30-2011, 05:02 PM
WS Sick's Avatar
People don't like to admit it sometimes, but a track and DA are worth a bunch in some cases. I run a full half second faster on the same track from winter to summer.
Old 01-30-2011, 05:09 PM
hmm so u were running a 26" tire, 4.10 gears, a yank SS3600 in a 4l60, and crossing the traps at 6200rpms?
good info for me, thank you.
edit: and WS Sick i agree i also run a 1/2 second faster/slower depending on the weather throughout the year.
Old 01-30-2011, 05:11 PM
sadly thats all i really know about the car, other then he had the tune spot on.
Old 01-30-2011, 05:16 PM
bowtienut's Avatar
No, sorry I was unclear about that. With the Yank, it was closer to 5800-5900. Only with the looser Edge converter unlocked was it up around 6200.
Old 01-30-2011, 05:29 PM
bufmatmuslepants's Avatar
Is the shootout not going to allow LS1 lids? That would blow haha
Old 01-30-2011, 05:39 PM
96silverram's Avatar
Okay, me too:
Tulsa, Ok. (Circa 2000ish) 1200' DA (that night IIRC)
Quick Reply: The Fastest Bolt On Only LT1's in the World List
