View Full Version : D1 procharger with 3.4 pulley... How much boost will it make? and what size injectors
firehawk68mcleod
01-30-2011, 11:47 PM
Im building an ls2 . wiseco -11cc pistons , callies rods, stock stroke. super vic intake and elbow ,90mm tb, ported 317 heads. and this is the cam that was recommended to me 224/228 .581/.588 114 LSA. What kinda boost levels will i see with my D1 procharger with a 3.4 pulley. and intercooler set up.... also what injectors should i run?80, 60lb ? thanks
Aster
01-31-2011, 12:33 AM
I would guess close to 18psi. For injectors don't forget the power lost for turning the blower. You will need the extra fuel, go for the 80's. S/C cars have a way of maxing out the 60's in the mid/upper 700's.
firehawk68mcleod
01-31-2011, 12:40 AM
SO im going to make tons of power probably...? im putting this engine in my 68 camaro with a six speed.. i was hoping streetable... Do u think i could use a bigger cam or go with this one?
LS1RedZ
01-31-2011, 11:05 AM
Im running the 3.4 pulley and seeing around 16psi. You might see more, who knows. I would definitely step up to some 80lb injectors. Mine are tapped out and I made 780rwhp, I just got my 95s in. If you dont have a cam already or have the money to switch I would go with a Brutespeed (EPP) blower cam. On the power question, yes your gonna make some serious power with that pulley and setup.
'Trust'
01-31-2011, 11:45 AM
I made 19 psi on that pulley, 75lb injectors were at 9X% so I went with 95's. Made 808rwhp through a 4L60E with that.
fatmat80
01-31-2011, 12:07 PM
LS1redz I have a similar cam to the op? How much power do you think could be gained from switching from a 224 ish cam to a brute speed blower cam? Sorry for the partial hijack..
On topic I think you will see from 14-18 psi with the pars listed above.
firehawk68mcleod
01-31-2011, 01:09 PM
Whats your engine set up.... im putting this in my 68 camaro with a six speed ... just for laughs... what kinda gas mileage did you get while you kept your foot out of it/ thanks
Tirefire
01-31-2011, 01:39 PM
Where did everyone buy their 95 lbs injectors? Also this might be a stupid question but are they supposed to be low impedance injectors??
ChevyChad
01-31-2011, 02:14 PM
Stock injectors are high impedance. If you buy low impedance injectors, you will need a driver box for your computer to be able to control them.
firehawk68mcleod
01-31-2011, 02:38 PM
What size injectors are you running... do you think 9-1 compression is ideal for d-1 3.4 pulley at 15-18 lbs. some say its low for our prochargers where its more idea for turbo set ups?
ChevyChad
01-31-2011, 02:41 PM
I am running high impedance 80# injectors. I'd say 9.0:1 is a very good spot to be with 18psi from a procharger for sure if you are using pump gas & meth.
firehawk68mcleod
01-31-2011, 02:50 PM
Also what fuel system are you running
pdasterly
01-31-2011, 02:57 PM
similar setup, 9.1 cr D1SC with 3.4 pulley, ls9 cam. waiting for new numbers. fic 80lb injectors, dual walbro in-tank with hot wire. I also have a boost a pump but havent installed yet.
old numbers - P1SC 12psi 550rwhp@5500 rpm
'Trust'
01-31-2011, 03:13 PM
9.7:1 396ci LS1
Diamond -15.9cc Pistons
Eagle H-Beam Rods
Lunati 4.125" Crankshaft
Victor Jr. Intake Manifold
IntakeElbows.com Elbow
NX 90mm Throttle Body
AFR 205cc 66cc Cylinder Heads
XP Custom Blower Cam
Kooks 1 7/8" Coated Headers
It made the same power on the LS6 intake, but the Vic. Jr carried it an extra 400rpm.
As far as injectors, mine were low impedance Precision's, 95lbs/hr, Acceleronics Driver box.
Then the ProCharger, no really sure on mileage, probably averaged 15-18. You'll do better in a 6 speed!
ChevyChad
01-31-2011, 03:16 PM
Dual in-tank 255 walbros (second one boost activated), -8AN feed, -6 return, boost referenced FPR, speec inc rails. supplemented by an alkycontrol single nozzle meth kit..
Check my garage by my avatar for full details about my car.
LS1RedZ
01-31-2011, 04:27 PM
Give Jon a call at (FIC) Fuel Injector Connection off of here. Got my 95lb High Impedance from him.
pdasterly
02-01-2011, 03:34 PM
Same here, I use them for all my builds.
firehawk68mcleod
02-01-2011, 03:43 PM
how much do the run
firehawk68mcleod
02-01-2011, 05:20 PM
what cam specs did you run
Tirefire
02-01-2011, 07:14 PM
I did he advise me that to get the horsepower I want (800 rwhp) he could either bore my 60 lbs injectors to 80 lbs or I could buy a set of 80 lbs. It seems 80 lbs aren't cutting it though!!
