Help...Buzzing noise when wheels spin
Old 01-30-2011, 11:55 PM
xxmerc1914xx's Avatar
Default Help...Buzzing noise when wheels spin
so i was driving around before and i noticed a very strange sound that almost sounded like something was rubbing up against the front tire. i checked all around the tire but i couldnt find anything that could possibly rub. i pretty sure its not anything with the engine or transmission because it only makes the noise when the wheels are spinning, not when reving in neutral. anyone have any ideas?
Old 01-31-2011, 01:28 AM
Nacho SS's Avatar
Halfshafts.
Old 01-31-2011, 05:51 AM
Tappeter's Avatar
Also check inside for loose abs sensor wire inside the wheel. The clip that holds the wire has been known to break or come loose
Old 01-31-2011, 06:48 AM
LS1>girlfriend's Avatar
Traction control.
Old 01-31-2011, 11:17 AM
called up chevy and they think its the wheel bearings so im gunna take it in and see if they can fix it
Old 01-31-2011, 04:06 PM
KB06GXP's Avatar
Yea, traction control. Shut it off and try to drive.
Old 01-31-2011, 05:10 PM
LS1 Racing's Avatar
I was thinking hub assembly, i.e., wheel bearings.
Old 01-31-2011, 06:38 PM
CenTexSS's Avatar
This. If you don't know what failing wheel bearings sound like it can be thought to be rubbing. And they're common to fail on these cars. I had a bad RH Front wheel bearing when I traded mine in.
Old 01-31-2011, 06:47 PM
Mgpeagle's Avatar
My guess is a wheel bearing too.
-Mike
Old 01-31-2011, 07:24 PM
MC06SS's Avatar
My Monte had a similar sound when the wheel bearings first started to go.... then it got louder and louder
Old 02-01-2011, 11:21 AM
Super LaX's Avatar
What's the mileage on the car?
Old 02-01-2011, 12:05 PM
vroom_vroom's Avatar
Yup time for new hubs if you can so both will eliminate problems I'n the long run
Old 02-01-2011, 12:25 PM
just under 50k i scheduled the service for friday, till then i just try not to drive anywhere.
Old 02-03-2011, 11:21 AM
wmlunt's Avatar
traction control...!
Quick Reply: Help...Buzzing noise when wheels spin
