Le1+Hot cam what injectors
Old 01-31-2011, 12:45 AM
henry172's Avatar
Default Le1+Hot cam what injectors
I am going to be building a stock bottom end lt1 with le1 heads and a hot cam. I think the stock injectors will not flow enough for this set up; what injectors would you recommend? And will a madz28.com mail order tune be good enough.
Old 01-31-2011, 12:50 AM
hitmanws6's Avatar
Id go with redtops, the SVO blue tops/ LT4 injectors might even work for you
Old 01-31-2011, 09:15 PM
WS Sick's Avatar
Injectors are easy to change, i would try the 24#ers first.
Old 01-31-2011, 09:19 PM
rich5368's Avatar
I can't imagine that the stockers couldn't keep up with that setup. If not though as previously said the LT4s will prolly get er done.
Old 01-31-2011, 10:02 PM
nomoneyz's Avatar
I don't have experience with madz28 but with head and cam work I would go with a dyno tune to get the most out of the combo.
Quick Reply: Le1+Hot cam what injectors
