403 STROKER what heads????
Old 01-31-2011, 10:21 PM
paul1379's Avatar
Default 403 STROKER what heads????
ok so im going with a 403 stroker. looking for about 11.0 to 1 comp. Im using a FAST 92 intake ported the has a set of heads already but i want to hear everyones opinion on it. the set they said were Trick flow LS 225. with a cam size of 240/244 .609/.615 112. yella terra rockers too. Is this a good set up?????????
Old 01-31-2011, 11:05 PM
SOMbitch's Avatar
Yeah TFS are really nice. That will be a STRONG setup
Old 02-01-2011, 02:05 AM
mkvamso's Avatar
will a cam that big not have ptv problems with those heads?
Do they have valve reliefs?
240/244 is a vindicator cam. Its super close in a stock headed car
Old 02-01-2011, 09:34 AM
dudeiwin86's Avatar
if hes building a motor, i would assume he has valve reliefs in the piston for the cam.
Old 02-01-2011, 10:24 AM
djfury05's Avatar
My buddy has a 408 t56 with trickflow 225s and made 511/472 and has run 10.80 on motor at 3600 lbs for his 2nd time at the track ever. Car has a lot left in it as well. Can't go wrong with trickflows.
Old 02-01-2011, 11:55 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Might checkout the PRC 237 heads. Also look for the Hot Rod magazine cathedral head shootout. The PRC 237 heads flowed the most air of all the competitors & had potential to really shine had the shootout not been so intake manifold limited. Take some time to study the data, I think you'll find the PRC 237 is a great option! not to mention they're about to be on a BIG SALE & are setup for stock rocker assemblies.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 02-01-2011, 04:55 PM
SOMbitch's Avatar
[QUOTE=mkvamso;14440704]will a cam that big not have ptv problems with those heads?
240/244 is a vindicator cam. Its super close in a stock headed car[/QUOTE
TFS has more PTV than a stock head because the valve angle is rolled back to 13.5* Unmilled that head/cam should even clear a flattop...
Old 02-01-2011, 08:12 PM
paul1379's Avatar
thx everyone for your input.
Old 02-01-2011, 09:06 PM
odarabla's Avatar
If it's a 403ci then the after market pistons come with valve reliefs.
Old 02-01-2011, 09:10 PM
odarabla's Avatar
I am getting my 402ci together as we speak. Those heads will work fine for that build. I am using the Trick Flow 215cnc heads opened up to a 4" chamber with a custom cam. The point of all this is to get a cam built for your application unless you aren't trying to get the most out of your combination. Just a thought..
Old 02-01-2011, 09:15 PM
odarabla's Avatar
There is no doubt your heads make power but lets be sure to let them know that after market heads like AFR or Trick Flow wasn't tested in that test.
Quick Reply: 403 STROKER what heads????
