1996 WS6 6speed Transmission shakes when i let clutch out?
When I'm at a stop in first gear and let the clutch out and press the gas the transmission starts shaking. Also when I put it in reverse and let the clutch out and press the gas the rear end starts shaking? Is the transmission mount broken. Also i have a spec stage 2 clutch.
My old Spec stage 3 would do it. It required more gas to get it to not shake when letting out. Are you giving it enough gas? Its aftermarket so its not going to be like a stock clutch.
Your right when i give it alot of gas it doesnt shake at all. Only when i try to take off slow and let the clutch out slowly it shakes a lot, then i guess it must be because of the clutch thanks
There's about 15,000 miles on it from what im reading on the receipt. Just bought the car last week so Im still trying to get adjusted to it.
