Cold start
Old 02-01-2011, 08:44 AM
bryan4694's Avatar
Default Cold start
Ok so when I start up my car for the first time in the day it will start fine but after running a min or two it starts missing pretty bad. It does it all the way until it gets fully warmed up. I met a guy last weekend and he told me it's my intake gaskets. I just want to know if anyone else can verify this before I rip my intake off?
Old 02-01-2011, 09:14 AM
bryan4694's Avatar
anyone?
Old 02-01-2011, 09:19 AM
BlueBeastSS's Avatar
I have a similar problem with my car. I have an ms4 cam and a few other mods. I have to give it just a little gas to get it started and hold it steady to get it to idle smooth and after i let it warm up i go to take off it missfires at first until i get it going at a steady speed. And it will do it sometimes after i stop and take off from a light. Tey told me mine was my air to fuel ratio is off and mu o2's are reading bad
Old 02-01-2011, 09:34 AM
bryan4694's Avatar
Have you had it tuned since the cam install, mine car is all stock but I dont have no rear o2 sensors so i think that could be part of my problem. I hear if you dont have the car tuned after cam installs it doesnt run right.
Old 02-01-2011, 10:21 AM
myk
myk's Avatar
You guys need to retune your cars, or else the PCM won't understand what's going on. You guys are probably throwing codes, too...
Old 02-01-2011, 10:35 AM
Yes i have had it tuned and im getting retuned again after i put new o2's and injectors
Old 02-01-2011, 10:39 AM
O2Form's Avatar
What is it? LT1 Ls1? mods?
Old 02-01-2011, 11:23 AM
bryan4694's Avatar
I dont have any major modds done enough to tune my car yet, I just scanned mine last weekend and the only code I am throwing is the o2 codes. I am going to have my car tuned after I get my heads, cam, and stall in.
Old 02-01-2011, 11:24 AM
bryan4694's Avatar
My car is a Ls1 car
Old 02-01-2011, 11:27 AM
O2Form's Avatar
Check the intake bolts, DON"T OVER TIGHTEN THEM!!!!!!!
Old 02-01-2011, 11:29 AM
bryan4694's Avatar
I will check them when I change out the gaskets
Old 02-01-2011, 11:49 AM
O2Form's Avatar
NO the idea is to check them before, there is no reason to change them if the bolts are loose.
Old 02-02-2011, 08:06 AM
bryan4694's Avatar
Well when i go to takew it off dont you think i would feel that they are loose
Old 02-02-2011, 08:07 AM
01ssreda4's Avatar
You didnt happen to seafoam the car did you
Old 02-02-2011, 08:21 AM
bryan4694's Avatar
lol not that i know
