what heads to go with
LS1Tech Premium Sponsor
What are you looking to do with the car? What kind of car (or truck) is it? What engine? What tranny (and stall if auto)? Do you have specific goals for the heads swap in terms of power or budget, etc??
Let us know some of this and we can make a recommendation that will fit your needs and goals!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Remember, don't worry too much about the numbers, worry about how it runs and performs.
I agree with wytry: Don't get stuck on the dyno numbers. That stalled auto won't be a sdyno queen like the 6 speed manual cars are!
For a budget oriented combo, the PRC Stage 2.5 LS6's will be a great way to go! We have them on sale for a tax time deal currently too!
__________________
If you have a set of 243 heads then the best value would be to send the heads to TEA for a stage II port job. Combine the heads with a Fast 102 intake and tb including all the prerequisite bolt ons and you will be over 450+rwhp with proper tuning.
Stage 1 LS6's
Stage 2.5 LS6's
We also offer competitive pricing on our porting services and can save you some money if you want to send us your castings to port!
Stage 2.5 LS6's
__________________
I'd give Matt a call, we have the heads going on special so I bet he can discuss options & hook you up!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
bryan i went with the patriot stage 2 heads and i am very pleased with my setup they work great made good numbers and also runs a good time at the track i have heard the prc heads are good also i just decided to use the patriots and i am pleased chad @patriot will help u out with any of your questions
Trader Rating: 0
So whats these cost and what kind of numbers are you putting out?
The only PRC's that are priced anywhere near the AFR's are the aftermarket castings....the ported GM castings are substantially lower in price than those are, and represent the "bang for your buck" heads!
__________________
Stage 1 LS6's
Stage 2.5 LS6's
Stage 2.5 LS6's
