Knock Sensors?
idk if i should replace them and get a retune
or retune and see it that fixes it, bc the guy had it tuned by a guy thats known for messing with the timing alot
just replace them.... its not hard to take the knock sensors out.... u just need about 3 hrs and u buying me a 12 pack of bud light... like 30min to take off the intake...30min beer break....15min to take out and install the knock sensors.....30min to reinstall the intake and 1 hr and 15min to get drunk and sober up to drive back down here...
Trunion King
This.
Also one thing it could also help if you do some research if it doesn't help you, you can isolate the problem by replacing/cleaning some sensors.
O2 you could probably replace them if you're still rocking the old factory ones or they are just bad.
Like someone said, you can clean the MAF sensor.
You can check your plugs if they are fouled or cracked/wires if they are frayed or not fully seated on the plugs or coils.
